ex369
Systems
Systems Posts: 14,872
edited September 2002 in Car Audio & Electronics
How good is the EX369 speaker, how would you compare it to the infinity kappa 6x9, the cmmd one.
thanks
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    personally i think its a bit better "SQ" wire than the kappa, but maybe not exactly as power hungry as teh kappa's ---
    they kappa's *green infinities* were close to teh old DX series polk coaxials... least in overall performance... not build (i'd never sit here and try to speak of build... i'm no speaker designer)
    personally i'd take the ex369's over the kappa's even with the slightly lower actual power handling figure because they give a richer more "real" tone, as opposed to the kappas which are more of a "rear deck only, for the love of god don't put that thing within a foot of my ear" speaker.
    i've owned the old EX II, the DX, as well as the Kappa's, and i was always happier with the polk stuff.
    The Artist formerly known as PoweredByDodge
