vinyl laminate
dougr
dougr Posts: 124
edited April 2007 in DIY, Mods & Tweaks
Any secrets to applying vinyl laminate (such as that available from parts express)? I have two RT16 bases with the old laminate peeling badly... would like to get professional look around these curved surfaces... is it possible, or should I just paint it black?
on another notes, is it difficult to relaminate polks with a different laminate (e.g. cherry vs black ash)? and has anyone had success with doing this (i.e. actually looks like it was produced that way)?
Thanks,
-Doug
______________________________________________
RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable :)
Post edited by dougr on
  • engtaz
    engtaz Posts: 7,675
    edited April 2007
    Good question I would like to know also.
    engtaz
  • Polk65
    Polk65 Posts: 1,405
    edited April 2007
    PartsExpress black ash vinyl 261-610 has some good stretch with a heat gun. I've never tried it with round corners but the feeling it gave while pulling makes me believe it would come out nicely. Paint would be an easier option.
  • zingo
    zingo Posts: 11,258
    edited April 2007
    Relaminating should not be a problem as long as you get the old lam off and clean off any glue, etc. I might even give it a very fine sand to make sure the surface is clean and smooth.
