Looking for a 3 channel amp
pmckeealaska
I need suggestions on a good 3 channel amp to power my center (LSiC) and surrounds (LSiFX's). Needs to be under $1000.
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Post edited by pmckeealaska on
Don't mean to hijack, but what about getting a 3 channel amp for your front stage and using your current amp for the surrounds?
A good point, but what makes you make that suggestion? I'm curious.Music and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Playstation 3 120GB Slim -
An equal amp for the front soundstage. It helps assure having the same sound across the front three speakers, essential for good imaging.
Or you could sell off the 1080 and go with the 1095 as it is the 5 ch version of your 2 ch amp. Sound shouldn't change and you would have all the amp you need in one chassis instead of two.
Off the top of my head for below $1000 if we assume used is acceptable you could go B&K 200.3, 125.3, Adcom GFA-5503, Earthquake Cinenova Grande 3, Anthem MCA30...
You could also go three monoblocks.
Jared -
The Adcom 5503 shows up on e-bay alot for under 1000.00
I have only seen one 3-channel Anthem on there but you could also try audiogon. Another option is 3 Outlaw 2200's or the older 200's. Anything new for under $1000 will probably not be worth it.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Brand spanking new & superb sound quality. A few bucks over your budget but well worth it.
http://www.avahifi.com/root/equipment/amplifier/omegastar_240_3.htm"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
lsi 9's -
Bryston also makes a 3 channel, and check out ATI as wellShoot the jumper.....................BALLIN.............!!!!!
