Question about CSi25
polkman888
Hi,
I have a question about the CSi25 Center Channel Speaker. The manual say nominal impedance is 4 ohm and compatible with 8ohm output. What does this mean? That means it can be used to connect to the center channel output which is setup 8ohm? can I use R300, R15 and CSi25 to build my system? Do they match each other? Since nominal impedance of both R300 and R15 is 8ohm, how to setup AVR to use R300, R15 and CSi25?
Any suggestion is appreciated!
AVR - Onkyo 804
Front - R300
Center - CSi25
Surrounds - R15
Sub - PSW303
AVR - Onkyo 804
Front - R300
Center - CSi25
Surrounds - R15
Sub - PSW303
Post edited by polkman888 on
They're not exactly bookmatched speakers, but they should work well together. I had a csi30 and my cheapo panasonic receiver didn't really have any problems pushing it. I think the onkyo will do just fine and if it has a 4ohm / 8 ohm switch leave it on 8ohms.
Welcome! -
Thank you, Michael!
