Wiring 8 MMC650's to a 4 channel amp
lib135
What would be the correct way, to hook up 4 pairs of Polk MMC650's to a 4 ch amp? Thanks!
Post edited by lib135 on
2-8 ohm speakers in series is 16 ohms.
2-8 ohm speakers in parrell is 4 ohms.
So on and So on. You have to know what your amp is capable of driving.
If you did 2 pairs of 2 in series then put the series pair in parrell you have 8 ohms.
This might confuse,
engtazengtaz
If the amp can handle a 2 ohm load per channel, I'd simply run 2 speakers in parallel on each channel.-Eric
-Polk Audio -
you can run 4 - 8 ohm speakers in parallel = 2 ohms
you can run 2 - 8 ohm speakers in parallel = 4 ohms
you can run 2 - 4 ohm speakers in parallel = 2 ohmsengtaz
