60 ft. hdmi or 60 ft. component
bondslex
Hi everyone! I was considering replacing an old component cable that is routed through the walls in my home with a hdmi. The only problem is the cable is about 60 ft. long. Do you think I'd loose video quality or have a problem with such a long run in an hdmi? Perhaps I should simply redo my component cable. What do you think?
LSI 15
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420
Post edited by bondslex on
Digital is always going to be better than analog over long runs. I would say go with an HDMI.If you will it, dude, it is no dream.
HDMI will be fine for that length. I'd get this if I was doing it.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024001&p_id=2893&style=&seq=1&format=1#largeimage -
errrr... _MAYBE_ it'll work. Analog will always sort work- you might get some signal degradation, but at least you'll get picture. With digital it either works perfectly or not at all. I tried a 50 foot HDMI run and it just didn't happen.
So buy from someplace where you can return it and be sure to do a test run before you put it into the walls
Backburner:Krell KAV-300i -
HDMI can't go over 25ft without the use of a repeater, anybody that would recommend an HDMI over this length (without the use of repeater) doesn't know what they're talking about. Repeater's can get expensive and hard to install; buyer beware.
Both. I am running HDMI,VGA,Component, and S-Video to my projector. All at 50ft.engtaz
http://www.bluejeanscable.com/store/dvi/index.htm
"The toughest in-use test an HDMI cable can pass is to deliver signals reliably over distance; our Blue Jeans Cable Series-2 HDMI cables have proven reliable out to at least 50 feet, while many others fail at shorter distances. In our own in-use testing, we have found that the 50-foot cable operates flawlessly at 1080p. Unlike many competing cables, the Blue Jeans Cable Series-2 HDMI cable is both UL-listed and rated CL2 under the National Electrical Code, making it lawful for in-wall installation in NEC jurisdictions (note: many cables are UL-listed without having an in-wall NEC rating; if it doesn't have CL2 or a similar NEC designation printed directly on the jacket, don't assume it's rated for installation.). The signal conductors in our HDMI cables are 24 AWG silver-plated copper, regardless of cable length, unlike many which use small-gauge wire at short distances. While a small-gauge cable may work well in a single short run, it is a potential source of trouble if you're using switches, couplers, or repeaters along the way. View the drawing and spec sheet on our Series-2 HDMI and HDMI/DVI Cables, in .pdf format."
Call or email to see, BJC may say you can get a 60 footer to work. -
I don't think Lush knows what he's talking about . . . never say never.
Maybe if you used 28 gauge HDMI cable, that is NOT suppose to be used for runs over say about 10ft. It all depends on the gauge of run, for different lengths.
I've ran over 25ft of HDMI cord with NO problems... -
I'm currently running 35ft HDMI cable, picture looks just as good as a 3ft cable.My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
Get some belden RG-6 and make your own component cable.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I got this one and have had no problems with signal degradation. Competitively priced and is a very nice cable. They sell it in all kinds of lengths.
http://www.hammerimports.com/item.php?id=173&name=HDMI_to_HDMI_Video_Cable_Hi-Grade_50Ft
Hope this helps.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
My math was off, it was 15 meters. I had converted incorrectly.
http://www.hdmi.com/about/faq.asp#connectors_cables -
That is one big math error.;) -
I got all my cables at monoprice premiumengtaz
Guys, I ordered both. They should be here in a few days. I ordered from mono and I am on the east coast. It will take a few days to arrive but I'll keep everybody updated.LSI 15
LSI C
LSI FX
80 fx ls for atmos
Velodyne SPL-10
Marantz 7012
Panasonic 9000
JVC 420
