5.1 in-ceiling setup with tc80i/rc80i fronts?
nagudhanwada
I have a 12X18 family room that is pre-wired for 5.1 in-ceiling surrounds. I need advice on which of the following in-ceiling options would work best.
1) All 5 RC80is (Front 3 + Rear 2)
2) Front 3 TC80is + Rear 2 RC80is (First of all would this combination work?)
3) Front 3 TC80is + Rear 2 TC60is
Option 2 is around 225$ more expensive than option 1, and Option 3 is around 160$ more expensive than Option 2. I am trying to decide on one of these options. Any advice is greatly appreciated. Want to make sure the extra bucks for some of these options is worth it.
One more question is I am planning on a psw-10 sub, and an onkyo sr674 to go with this setup. Are there any big gotchas with this setup?
Thanks in advance..
- nag
Thanks in advance..
- nag
Post edited by nagudhanwada on
If you can swing it, of the options you listed, #3 would be the best, by far. The TC in walls are nice, I am not a fan of the RC's at all.
If you look hard on ebay, you can get the TC80i's for very cheap, and I tell you what, 5 of those would rock!"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell -
Oh, the PSW10 is pretty much junk. I know that is strong language, but search here and you will see it is not well regarded at all. Dunno about the Onk AVR though, maybe someone else can help you out on that part..."People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
I would go with op.3, the TC series are really nice sounding speakers.
Dave -
Thanks sbpolk and Dave for your responses. Guess I am going with the tcs...will see how it works out.
Would the TC s really work well as LCR fronts? Are you guys fans of in-ceiling front channel speakers in a 5.1 set-up other than the new LCi-RTS100 which sound great but are really pricey? I am considering 5 LC80i but someone mentioned that there would be dispersion issues with in-ceiling speakers.
Option 2 would not be timbre matched.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
just an update..getting 3tc80is+2tc60is...800$ shipped ebay. any advices on a budget sub to go with this configuration. thanks.
svs or hsu come to mind."People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
I, for one, like in-walls. If I had a choice between nice inwalls and satellite, Bose, or HTIB. . . I'm going Polk inwalls all the way.
People will tell you to look at SVS subs. Depending on room size, they can run $450 for some (Bstock) up to $1500. Any of them offer excellent value.
I have a Mirage Omni S12 and like it. HSU is another good one.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
