Oppo Question: 981HD
SolidSqual
So I'm on the verge of buying this player, but before I do . . .
What is the best method to hook-up my 2-channel system to this player? I want to get into SACDs and DVDAs, but I'm afraid if I use the 2-channel downmixed connections I will not be getting the full resolution of the SACd or DVDA. If I use the 5.1 outputs, will I be missing signals sent normally to the surround and center channels? I noticed one of my SACDs can be played in stereo. Is this a menu selection? HElp . . .
Post edited by SolidSqual on
I have this player, but Im just connected via HDMI. I wish I knew the answers to your qs. I can tell you this though, its a very solid player and the Sq is great. Again, wish I could tell you more.Shoot the jumper.....................BALLIN.............!!!!!
You'll only lose information if you select the 5.1 mix on the player and choose the 5.1 mix on the source. Stereo CDs play only in the front unless you tell the player you have a sub and select Small for the speakers. 2 channel SACD/DVD-A tracks are on all the disks that I've seen. You'll be fine.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I've had my eye on this player as well.
so sacd should not be a problem2 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
Oppo Digital weighs in . . . It only took them 3 hours to return my email!
Michael,
For SACD you can set the priority to 2-Channel Stereo. So all other
sources will be in 5.1 audio, while SACD will always be 2.0 Stereo.
Best Regards,
Customer Service
OPPO Digital, Inc.
453 Ravendale Dr, Suite D
Mountain View, CA 94043
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119 -
Is this method possible for DVD-A as well?
I got the 970 and it plays everything you can think of which is quite a deal for $149.00
http://www.oppodigital.com/dv970hd/dv970hd.htmlMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
I'm in the process of negotiating for a 971H. I heard somewhere (not sure if it's true) that unless you have a 1080p, the 971H would work best as it would better match the lower native resolutions? I don't know...I'm new at this. I guess if you planned on going 1080p in the future it wouldn't matter. The bad thing about the 971H is that the upconversion only works through the DVI connection. Unless you've got a DVI or HDMI you can use that feature!2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
You are correct, upconversion only works from the DVI out on the 971. They do provide a DVI/DVI and a DVI/HDMI cable with the player.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
You are correct, upconversion only works from the DVI out on the 971. They do provide a DVI/DVI and a DVI/HDMI cable with the player. If your TV doesn't have DVI or HDMI in, I'd opt for the 970.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Upconversion only works on HDMI or DVI on all their (and most other brands) players unless you have a hack for it. Last I checked the 970 is the only Oppo that had a hack available but it's been a while so that may have changed.
The 971 and 981 will work equally well for a non-1080p set"The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Disc Jockey wrote: »Upconversion only works on HDMI or DVI on all their (and most other brands) players unless you have a hack for it. Last I checked the 970 is the only Oppo that had a hack available but it's been a while so that may have changed.
I use the oppo with the hack so it will upconvert via component video cables and there is now an updated firmware hack that works very well with the player , and I am very happy with the player since I bought it in janurary of this year..:DMy gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
