Carver integrated amp
NeilGabriel
OK, shoot me now if I need more posts to discuss buying something. Also, you can check out my feedback at ebay for mms3rd or go to my business website (shultzemploymentlaw.com). I am looking for a good used carver integrated amp to go with the carver cd player I have and to use with the new/used SDA-CRS+ speakers Stubby just sold to me. If any of you audioholics have a better idea on an integrated to use let me know. Price preferably in the $250-$450 range. If that isn't enough money to get something decent used, then I guess I'll go back to my Phillips boombox. Thanks. This site has been a big help over the years. Mike (a 50 something audio dope).
Post edited by NeilGabriel on
NeilGabriel wrote: »OK, shoot me now if I need more posts to discuss buying something. Also, you can check out my feedback at ebay for mms3rd or go to my business website (shultzemploymentlaw.com). I am looking for a good used carver integrated amp to go with the carver cd player I have and to use with the new/used SDA-CRS+ speakers Stubby just sold to me. If any of you audioholics have a better idea on an integrated to use let me know. Price preferably in the $250-$450 range. If that isn't enough money to get something decent used, then I guess I'll go back to my Phillips boombox. Thanks. This site has been a big help over the years. Mike (a 50 something audio dope).
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all -
Thanks a lot. I have been tracking ebay, but thought I might check with a group of "honorable" polk groupies rather than give money to some flea shop in the cayman islands.
Mike -
you can go to audiogon and peruse the Solid State integrated amps for sale there, too. Most will be above your range, but I think there's a solid option or two for your budget.
Are you opposed to separates? If you could get a preamp and amp in your budget, would you consider that as an option?Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I'm not opposed to separates, just looking to save a little money with integrated and never used separates. Thanks on the audiogon referral. I think I have been on that site. Mike
