Oppo 971H question
dragon1952
http://www.oppodigital.com/opdv971h.html
I'm assuming since this has all the decoders built in that I could get by with just this plus a 5 channel amp and I'm all set for HT? In fact, I've got a Pioneer Elite with a preamp problem. Couldn't I just hook this up to the Pioneer and use only it's amplifier section?
Post edited by dragon1952 on
dragon1952 wrote: »http://www.oppodigital.com/opdv971h.html
Yes you can since the oppo has a volume control.In fact, I've got a Pioneer Elite with a preamp problem. Couldn't I just hook this up to the Pioneer and use only it's amplifier section?
Assuming the direct inputs work you could go this route.
Only one way to find out for sure, hook it up and try it.;) -
Thanks for the input. I don't actually have the Oppo yet. Just exploring options.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
