Ohm Issues
Meechsterlee
I have question on how to get more out the amp I have to drive my sub enclosure. At present, the amp is running aat 4 ohms...500 or so watts RMS...not enough for the L7 I have connected.
The amp in question is a HiFonics Brutus 1606D that is claimed a single channel amp but has 2 pos/2 neg terminals for power output. Can I bridge these and reduce the ohm load to 2 ohms?
The sub enclosure I have is a Kicker 06-VS12L7-4 (12" solarbaric Dual 2 ohm VC's) I understand the driver is wired parallel...so this becomes a 4 ohm speaker?
Thanks in advance for any help on the issue. I am not so car audio savoy yet.
SAMSUNG HL-S42 DLP
harman/kardon AVR225
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000
Post edited by Meechsterlee on
if each chanal is 2 ohms stable then they can be bridged but you must have a 4 ohm load. if your amp you have now is 1 ohm stable then you can rewire your sub for a 1 ohm load.Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
So am I to wire the sub in series parallel?SAMSUNG HL-S42 DLP
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000 -
Nevermind...I'm such a dork. The speaker is in series...I need to wire it parallel to get the 2 VC's down to 1 ohm. Got it. Thanks at any rate.SAMSUNG HL-S42 DLP
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000 -
The amplifier has two set of terminals to make installation of more than one woofer easier. It is still a monoblock. As far as power goes, be careful with the gains.....at 2 ohms it will throw out 1100 watts RMS, and 1600 watts RMS at 1 ohm.
My sub amp (1500xxk) puts out 1100 watts RMS at 2 ohms. This is obvioulsy way too much for my JL sub, so I backed down on the gains and use common sense witht the volume control.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Meechsterlee wrote:Ohm Issues
It takes time, practice, and patience. But you can do it.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
I guess you were thirstyAlpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
No joke about the gain...
Overall, quite impressive for one sub. Thanks much!SAMSUNG HL-S42 DLP
SONY PS3
polkaudio RTi8's
" CSi3
" RTi6's
Velodyne VRP1000 -
dude... dropping from 4 to 1 ohm... you're going to pretty much quadruple your power... be careful, the shockwave of sound might blow your wee wee off.
Edit Note: --- be careful how loud you play it initially... if that amp does 1600 x 1 or something at 1 ohm, then you may be overpowering the sub and need to pull the gains back.The Artist formerly known as PoweredByDodge
