what are some good tube amp manufacturers
JimBRICK
JimBRICK Posts: 1,543
edited April 2007 in Electronics
Most of you guys have stuff from all the best makers. who are some good manufacturers
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2007
    The list is long and distinguished.
    You want something vintage? Used on a budget? Giant Killers? Power and pricepoint are always a good place to start, what do you want to drive, and what can you spend?
    Cheers,
    Russ
  • JimBRICK
    edited April 2007
    I want to power a set of lsi15's and a lsic and later a sub and surrounds.
    but for now just the lsi15's and center channel.
    dont want to spend a fortune and will be looking all over for something preenjoyed :)
    I just want to know what manufacturers to look for.........the only ones I know right now is macintosh and jolida
    2 CHANNEL
    Under construction
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited April 2007
    McIntosh will run you a small fortune.....Cary, Conrad Johnson, Sonic Frontiers.....There is quite a long list, like Russ said.......$$ plays a big part of it.....I have heard jolida is a great bang for the buck.....The only tube piece I have is a Carver 490t cd player at the moment.....
  • RuSsMaN
    edited April 2007
    I'd look for stereo amps in the 40 to 60 watt range, and bi-amp your 15's and c each with a single amp. Jolida is great, so is Anthem, Quicksilver, Cary / AES, BAT, etc.
    A few members have been using 'TAD' amps, with good sucess on a budget. The Primaluna stuff out of China has gotten rave reviews recently.
    Don't rule out hybrids either, such as Counterpoint (tube front end, sand output).
    I've been hording old Sherwood mono tube integrateds to hotrod for a 5.1 tube setup one day.
    Cheers,
    Russ
    tonyb Posts: 33,072
    edited April 2007
    Russ hording gear???? Naw...Would love to peek in that closet.
    Have you thought of a tube pre and SS amp?Might be happier in the lower regions going that route.
    Check out Butler hybrids also,very musical and can be had on the used market at good prices.
  • 55LS70
    55LS70 Posts: 184
    edited April 2007
    I just got a Primaluna Prologue 4. Initially I was kind of leary of the self biasing feature, but quite frankly, it sounds great. Considerable improvement over the Dynaco ST70 Series ll it replaced. You probably couldn't go wrong with a TAD either. I think both in the same price range. Good luck in whatever you go with.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
