WTB Carver M-1.5t or M-500t
skipf
skipf Posts: 694
edited April 2007 in Wanted (WTB) Classifieds
Looking for either (or both) in excellent condition. My amazing Plats need power, they are hungry suckers.
Post edited by skipf on
  • avguytx
    avguytx Posts: 1,628
    edited April 2007
    In here, you'll just have to check the classifieds once in awhile or do a search for it. You'll sometime see them come up. Otherwise, try the usuals....Ebay and Craigslist. There are always some popping up. The ones on Ebay are getting quite pricey anymore.
    You can also try the Carver forum. It's a little slower than in here for getting a response but they pop up there too.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2007
    skipf wrote: »
    I've tried the m1.5t with the Amazing Plats, its not enough for them. You owe it to them to get more power than that.
  • avguytx
    edited April 2007
    There's a TFM-75 on Ebay...THAT will drive the hell outta them! lol
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    maybe an M4.0t would do them justice.
    Oh, and maybe I have one.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited April 2007
    That TFM 75 would do 'em justice....or a sunfire 300x2 or 600x2..... There is no such thing as too much power for those.....:D :D
    treitz3 Posts: 20,119
    edited April 2007
    If the M1.5t will not produce, like Shizelbs says, then a M4.0t will not be able to handle the task either [25 watts RMS more, but significantly less headroom]. Two m1.5t's wired correctly to the lower binding posts only (one per speaker) and another amp dedicated to just the top end of the plat's should work.
    Even if you bridge two M4.0t's mono, you still won't have the headroom that two M1.5t's would be able to deliver. Plus the damping factor will be improved for bass control.
    My 2 cents....
