Surround Upgrade? Worth it?
Sherardp
Sherardp Posts: 8,038
edited April 2007 in Speakers
I wanted to run this by you guys to get an opinion on a potential upgrade. I currently have the FXi3 surrounds and was wondering that since Im soon to be in a dedicated theater should I upgrade to the FXi5s. The room will be about 20x30 with 8 feet ceilings. Is it worth it to upgrade or should I just not worry about it and save the coin? Help..............
Post edited by Sherardp on
  • Early B.
    Early B. Posts: 7,900
    edited April 2007
    Don't worry about it.
    A better "upgrade" would be another Outlaw for the center channel and/or removal of Monster cables where it counts most.
    "God grooves with tubes."
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Early B is right. Outlaw = 200 watts for center, to me is a must.
    engtaz
    engtaz
  • Sherardp
    edited April 2007
    Thanks guys, I ordered the 3rd outlaw Monday. It is on the way as we speak and yes I have since then gotten rid of all my monster interconnects minus the DIY speaker wire and gone with signalcable. I upgraded the power cords with SignalCable on my AVR and CDp as well. I was just wondering if I would notice a huge difference in sound with the 5s.
