TrueRTA
jakelm
jakelm Posts: 4,081
edited April 2007 in Electronics
I'm tyring to figure out wether the basic version will do or should I puchase the upgrade.
I'm giving my system an Eq job. Mainly dealing with a crossover in my center channel and subwoofer calibration.
I have searched through this forum for the topic of TrueRTA and came up with little next to nothing.
Is the basic version enough to do the job or should I concider getting the upgrade?
Also (I dont know if anyone would know this) but would the mic that came with my HK 635 do a good job in reading Fr responce with TrueRTA. I did notice the mic was a stereo mic and not a mono. At least thats what the plug looks like. Or would my analog Rat-Shack meter work better?
I appologize if this topic has been covered before. I havent had a chance to play around with TrueRTA but would like to get some opinions and and maybe some tricks from you all who have experience with this calibration tool.
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2007
    The free version of TrueRTA is not very detailed across the octaves. I paid for the Level 4 and it was worth it.
  • PolkThug
    edited April 2007
    You'll need correction factors for cheap mics. The Rat Shack really craps out on the lower frequencies.
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    PolkThug wrote: »
    When you say detailed, you mean because its 1 full octave and not 1/4 or 1/2 octive?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    PolkThug wrote: »
    What do you think of the HK meter? It seems to work great for the AVR.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    The free version isn't a great analyzer, but it is a great sound generator. You can send signals all across the whole scale one Hz at a time.
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    ben62670 wrote: »
    See thats the problem. I have sine waves already on cd. When I play audio from my PC to my AVR, I have a terrible ground loop. I think the hummm would mess with the readings. So reading the FR's would be probably the only job the RTA would do.
    I think the ground loop is coming from the sound card not the cables...thats a whole other project...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PolkThug
    edited April 2007
    jakelm wrote: »
    Exactly. You miss a ton of detail.
    Here's my trip to the darkside:
    http://www.polkaudio.com/forums/showthread.php?t=23534
    http://www.polkaudio.com/forums/showthread.php?t=23945
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Great job PT, have you tried RTA in the higher Fr's too? Or just the sub?
    And I keep reading on mic correction? How do you know if your mic needs to be corrected? The only reason I know about the ratshack being off is because I read about it. Other wise I wouldnt have known.
    How would I go about testing my HK for correction with RTA?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    AAARRRRGGGHHH,,,, I cant get this software to work.
    I plugged my mic in...tested it..it works fine. I can hear it perfectly through my speakers.
    I ran TrueRTA, clicked RTA and set my CPU speed to 3 and octive 1, in the analyzer menu. Then clicked for SPL. Then clicked go. All I get is an analyzer line jumping up and down between 18hz and 24khz. I ran a 2khz sine wave. Nothing happened, the same analyzer lines never adjusted for the 2khz spike.
    I know my mic works...
    Is there a step im missing?
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Schwingding
    Schwingding Posts: 363
    edited April 2007
    Actually the radio shack meter is pretty good at the low frequencies, but sucks at above 2Khz.
    Buy the full version - well worth the additional resolution. If you're serious enough about this to examine your frequency response - really do it.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Im using my mic that came with my HK AVR. A very good mic I might add.
    I'm not getting any responce from TrueRTA, with any meter. The wavy analyzer lines never change with any Fr I play.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
