Help with speaker wire connectors
1lakerfan
Alright I just got some 12 guage wire with the Gold Plated Locking Banana plugs from bluejeanscables.com. I unscrewed the set screws put the wire through the banana plug and wanted to know do I tighten the set screws on the insulation on the insulation or the copper wire or both? Here is the link to the instructions.
http://www.bluejeanscable.com/store/...ermination.pdf
Post edited by 1lakerfan on
To me I would say that you would be locking it on the wire itself. When you strip the wire 1/2" to 5/8" where does that put you in the plug? It looks to me like you'd be on the wire and that is the point. Let me know, I wan't to get the same ones. Dave
the copper strands right?
yes the copper strands. it has to make contact with the screw and wirePolkFest 2012, who's going>?
