Is this worth my time?
zingo
zingo Posts: 11,258
edited April 2007 in Electronics
Ad from Seattle's Craigslist reads:
QUINTESSENCE GROUP POWER AMPLIFIER II in very good condition. Output rating per channel unknown but probably 150 to 200 watts per channel. Final output stage for each channel uses 8 2N6031 transistors (NTE 61 is the equivalent with max. rated power dissipation 250 watts). All electronic components are discrete-no multilegged chips. Panel mount, approximate weight 50 to 60 pounds. Amplifier dates from the middle 70s. No specs available anywhere. Google search reveals nothing, similarly for Sam's Photofacts. The manufacturer was located in Sacramento California. Dimensions 18 x 16 x 6 inches exclusive of handles. Amplifier cooled by a large quiet muffin fan. $200.
Selling a product you are not sure of for $200 is a ballsie move. The attached pictures are ones that he provided. What do you think?
1.jpg 12.6K
2.jpg 15.1K
  • read-alot
    read-alot Posts: 812
    edited April 2007
    No it is not.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
