Subwoofer Amp
MSALLA
I was going to buy a plate amp and mount it in a remote box but I am thinking about going with an actual stand alone type amp. Can anyone recommend a good sub amp. I'd like one with a volume control.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
Post edited by MSALLA on
im also in the same boat my psw404 is clipping at mid volume. thought it was the sub but it turns out its the polk audio amp thats in there so now im guna buy a deadicated amp for it n bypass the amp. i saw sum audiosource amp cheapy for 200. 250rms 4ohm looks like a good deal
I'm pretty pleased with the plate amp I just picked up from rythmikaudio. 350w @ 4ohms, selectable rumble filter 14, 20 & 28hz, selectable damping, crossover/phase/gain, yada yada. The benefit IMO is that it will protect the driver from overexcursion though if you're careful a stand alone amp will be fine too.
http://www.rythmikaudio.com/amplifiers.html
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
+1 Rythmik audioMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Ron Temple wrote: »I'm pretty pleased with the plate amp I just picked up from rythmikaudio. 350w @ 4ohms, selectable rumble filter 14, 20 & 28hz, selectable damping, crossover/phase/gain, yada yada. The benefit IMO is that it will protect the driver from overexcursion though if you're careful a stand alone amp will be fine too.
That looks nice. If I go with a plate amp I think it will get the nod.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
look into velodyne they might still make stand alone sub amplifiersJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
Boston Acoustics
I'm using an Adcom GFA-555 bridged for 850watts at 4ohms lots of headroom, and high dampening factor. My box is going to be a SonoTube with a Dayton 15" Titanic driver. It handles 800 watts, but I was thinking about Using a 2 channel amp. You could use one for the center, and one for the sub. 555's can be had for $350, and put out 325@4 ohms, and 200@8.
Happy hunting
Ben -
I like stand alone amplifiers with home subwoofers. Not only can you trade drivers or boxes in and out as you please, but who doesn't like to add another amp to their stack of electrical bliss. If you have a really amplifier, you should show it off. It's sad to see good amps tucked away from prying eyes.
Try Dayton Audio's HPSA1000-R because it is specifically made for subs. It rates a 1000w RMS at 4 ohms and is on sale right now for $350 at PE. It's a hard amp to beat for what you get.
• Measured power output: 512 watts RMS into 8 ohms @ 0.09% THD, 1,024 watts RMS into 4 ohms @ 0.15% THD • Signal to noise ratio: 98 dB (A-weighted) • Parametric EQ: Frequency: 18-80 Hz, Level: -14.5 to +6 dB, Bandwidth: .1-1 • Low pass crossover: 30-200 Hz • Phase: 0-180°
http://www.daytonaudio.com/audio/audio_amps_sub.html -
+1 Rythmik audio, here too. Mainly for the LT board (I like sealed subs).Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
