Help with 6.1 Speaker Recommendation
I have a pair of RT1000 front speakers, two rear RTi25 bookshelf speakers, and a center RT300. I'm trying to expand to a 6.1 configuration and need to purchase a rear center speaker and a subwoofer. Can someone please recommend which speakers I should buy to round out my system?
Thanks.
Post edited by ttreakle on
Welcome, but more info is needed. Budget,room size, etc. The more the better.
Dave -
recommend 12" sub Model depends on budget.
engtazengtaz
Welcome.
All the questions above but would it not be a good idea to put the same center channel in the rear as you have in the front. Just a question as I not gone down the 6.1 road. Good Luck.Michael
NORTH of 60°
