Question for those with Harmony remotes
krabby5
hey all,
I'm thinking of switching from a large, heavy Sony remote to a Harmony 550 or 670..
Can you do custom macros with the Harmony's? For instance, I see "listen to cd" as one of the activities on the Harmony remote..
Can I change this to "Listen to iPod" and create a macro that would change receiver to iPod (as opposed to DVD, tv, game, etc)?
or am i stuck using typical macros that are found on the website for download?
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
You can customize any activity, and you can re-name them as well.
I have the 520, which is pretty much the same as the 550, it works very well, even my wife loves it. -
They are macro driven, but they write the macro's not you. You can name them you can modify them, light years ahead of past remotes if you remember those. Which you needed to learn the remote which you what'd key it in then think about all the steps you needed to make it all work.
Harmony remote you plug in mini usb cord connect to pc logs in Harmony website, you tell it what you got then it makes the macro's needed for what you asked for.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Yes on the 550.
engtazengtaz
I would do a Universal Remote MX-850.
Though this response has absolutely nothing to do with the OP's question, I will bite.
Cursed, why would you not recommend the remote the OP asked about if it does everything he wants and costs half the price of the one you are recommending? :cool:Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
thanks guys..
I ended up getting a Harmony 720 that was on clearance at Target of all places..I wasn't even going there to look at remotes..they had it for $139..
funny how those things happen..Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
