Lack of bass from LSi25's
pmckeealaska
I have been having problems with my system since August of 2006. First, I had to send my right channel LSi25 speaker in for subwoofer and crosover repair, then I found out that my NAD reciever was seriously messed up and had it repaired. Now, after having the NAD back, I found that the amount of bass I am getting out of my speakers is much reduced. I sent it down to another guy in California that NAD recommended and he called back yesterday to say that the unit is working perfectly! Arrghh!!! I can only assume that I am doing something wrong in the setup menu for the reciever, but am not sure where I'm going wrong. I used to have my mains set to large, then the NAD guy recommended I set them to small. The crossover is set to 120 (same as it used to be). Bottom line is, the amount of subwoofer is nowhere near where it used to be and in the test tone menu, I noticed that the subwoofer channel level was set to 8 or 9 dB louder than I used to have it and it STILL gave me very little bass. I have no idea what i'm doing wrong and am beyond frustrated. I anyone has any step by step setup instructions for my speakers or is knowledgeable about my NAD T763 reciever, please let me know as I'm clearly in need of someone who know what they are doing. I thought i did know, but clearly do not. I miss my music!!
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Post edited by pmckeealaska on
set your crossover to 80 and your speakers to large.. if that doesn't give you more bass, then something is wrong..
also check your speaker connections. if they are crossed and plugged in backwards, that will also impact bass output. I had this happen to me just this week as i was moving things around. It's easy to get the speaker wires turned around.
Also check to see if the jumpers on your LSi25's is in place or not. if it's not in place, you would not get any bass, unless you were running bi wires.PolkFest 2012, who's going>?
Hmmmm....I did remove the jumpers recently, but on polks subwoofer setup forum here, they recommend removing the flat metal jumpers from the input terminals to get "that last bit of sound quality". I'm now officially confused!Music and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Playstation 3 120GB Slim -
put the jumpers back. see if your bass returns. good luckPolkFest 2012, who's going>?
OK...I'll give it a try. Thanks for the suggstion!!:DMusic and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Or, replace the jumpers with speaker wire from neg to neg and pos to pos. I think that was probably the tip you saw on the forum. Speaker wire of quality is supposedly better than the brass jumpers. . .Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Wow... ya, definately put the jumpers back in. :eek:pmckeealaska wrote: »Hmmmm....I did remove the jumpers recently, but on polks subwoofer setup forum here, they recommend removing the flat metal jumpers from the input terminals to get "that last bit of sound quality". I'm now officially confused!"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell -
why put the jumpers back in? please educate me on this matter...:DMusic and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
if you remove the jumpers that tie the binding posts together.. and you only use the upper posts, it will only activate the tweeters. if you only use the bottom binding posts, it will only activate the mid range drivers/woofers.
put them back NOW!!!!!!! :eek:
(unless you are bi-wiring/ bi amping, then leave them off).PolkFest 2012, who's going>?
message recieved...i'm still amazed by ignorance sometimes!!:eek:Music and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
did it help with your bass?PolkFest 2012, who's going>?
i'm out of town right now. I wont be able to check on it till next week. will let you know. I hope its that simple!Music and Movie Rig
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
