Dancin' Drivers
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited September 2007 in 2 Channel Audio
I noticed that when I play music on my turntable, the drivers of all my speakers are a bit more active then when using a digital source. Even at the same volume, there is a considerable difference in the way the drivers behave. This has been the case with three different pairs of speakers... so I know the issue isn't down that alley.
In fact, I'm not even sure it's an issue since there seems to be no audible problems.
So... is this normal? And if not, any suggestions?:confused:
Post edited by zombie boy 2000 on
  • madmax
    madmax Posts: 12,434
    edited April 2007
    That is the subsonic rumble. It is some amount of feedback between your TT and speakers and/or possibly a physical movement of the stylus. It robs power from the amplifier and can damage speakers if its too bad. Until you hear bad things coming from the speakers I wouldn't worry too much but you could try moving the table or placing it on something different.
    Vinyl, the final frontier...
  • zombie boy 2000
    edited April 2007
    I emailed the good folks at Pro-ject and they said the exact same thing concerning feedback between the TT and speakers. As I said, there's nothing audible, but the activity is a bit "violent".
    Since I'm a complete and utter newb when it comes to spinning vinyl, could you expand upon your "stylus movement" theory?
  • zombie boy 2000
    edited April 2007
    Maybe that's why they call it "sub-sonic", eh?:p
  • dkg999
    dkg999 Posts: 5,647
    edited April 2007
    In the old days, many pre-amps, integrated amps, and receivers had a sub-sonic filter option to eliminate this. It was kind of a non-audiophile easy way out, but it would eliminate both the sub-sonic rumble and your need for speakers that dug low or a sub-woofer.
    DKG999
  • zombie boy 2000
    edited April 2007
    True... but are there any speakers or subs that can dig that low? It's my understanding that this is product of frequencies well below 20 Hz. Maybe I'm wrong...
  • madmax
    edited April 2007
    They are very low frequency, maybe up to 30 or 40 hz but most likely lower. Subsonic filters are considered by many to be non-audiophile not because they cut those frequencies but because in the best setups sometimes there is a change on up in the audible frequencies just because the filter is in place. Comes back to that old issue of tone controls causing problems.
    Movement of the stylus (moving around on the record because it is off center, warped, heavy arm moving because of momentum in a warp, or bad bearing) can be seen. Look closely at the needle and see if it is acting like the suspension on a car, bending up and down while keeping the arm fairly stationary.
    madmax
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    when i play an album, I have to raise the volume up to nearly 50% on the pre amp to get a good level.. when doing that it (the needle) picks up more noise.. is this common? Why does vinyl need so much volume?
    PolkFest 2012, who's going>?
  • zombie boy 2000
    edited April 2007
    madmax wrote: »
    So basically... the arm should be moving and not the stylus. If I go home tonight and find that the stylus is moving like a "car suspension", what actions should I take?
  • madmax
    edited April 2007
    That means one of two things. The first possibility is the arm is a high mass (heavy) arm and your cartridge is meant for a light arm. This has nothing to do with the tracking force you have set. The second possibility is you have the tracking force set too light or heavy. Too light causes it to be bouncy for light warps, too heavy causes it to be too bouncy for bigger warps.
    Edit: I'm sure there are better ways to explain this, I'm just not good at it.
  • zombie boy 2000
    edited April 2007
    You're doing perfect Chuck...
    I really appreciate it.
    To clarify a bit, I have the Pro-ject Debut which comes with a premounted cartridge -- so that rules out one of your scenarios. Due to the TT's hazy instructions, setting the tracking force has been an adventure. However, upon further correspondence with the manufacturer, I thought I finally had it set.
    Your ideas above have me thinking otherwise....
    When you say "warped"... is that something that could be relatively invisible to the eye? The records I own all appear unwarped. But maybe my conception of the word is way off base...
  • madmax
    edited April 2007
    Very few records are actually flat OR warped. I mean warped in a minimal way as in not quite flat. Back to feedback, I would suggest moving your table around as a test, even if you don't plan to leave it there. When I moved mine around I found it sounded different and had different characteristics depending on where I put it in relation to the speakers and what I placed it on.
    madmax
  • zombie boy 2000
    edited April 2007
    I should probably re-check how level it is, as well. Thanks for all your help. This should be fun.
  • zombie boy 2000
    So I pretty much have eliminated most of the rumble in my set-up. A bit of balancing here and there, and placing a Wii right by it seemed to be a recipe for success.
    However, the oddest thing happened on Saturday. I was watching Grosse Point Blank and a scene where Cusack starts spinning some vinyl comes on. I **** you not when I say the subsonic rumble came back in full force.
    Now... I know, I know. This has nothing to do with my TT. This was courtesy of the good folks at Dish and TNT. But it was there, nonetheless.
    Any ideas????
  • avguytx
    avguytx Posts: 1,628
    Do you have a concrete foundation or crawl space where you live? I never get any subsonic movement from my speakers/TT set up but the concrete foundation and a level mount help that out for sure. The only time I get cone movement is if I bump the TT while it's playing...I hate that. How far is the TT from the speakers? I remember when I was around 15, I had a Technics TT and a pair of Sansui (non-kabuki) speakers and had some subsonic action go on a lot. It seemed to be more predominant on acoustic suspension speakers than ported. Weird, I know, but that's what I remember.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • zombie boy 2000
    Crawl space and the foundation is a smidge uneven -- at least according to the home inspectors.
    Not enough to be problematic in anything but setting up a TT.
    That being said (and it was), I'm more curious about how I would get a noticable amount of rumble from a record being spun in a movie. It just doesn't make any sense to me. But I'm probably missing something here and it may be perfectly normal.
  • madmax
    I record a lot of vinyl. Whatever is happening during the recording process is exactly what you get when you play it back. (remember, the cartridge/record is a big microphone). If I record something with the speakers bouncing around, then that is what I get when I play it back. If I had the volume all the way down and the speakers were not bouncing, then they don't upon playback.
    madmax
  • zombie boy 2000
    Makes sense to me...
    so maybe I'm not completely insane.
  • danger boy
    what receiver are you using? i had a terrible rumble problem with an older Luxman 7070DB month's ago. Since then.. the rumble from my TT has been nearly eliminated. try a different receiver if you have one..
  • Ricardo
    Ricardo Posts: 10,636
    No rumble here; Bass "moves" my recliner but it seems no feedback (or whatever it is) reaches the TT :)
    SOPA
  • madmax
    I wouldn't want to go too far. :D
  • zombie boy 2000
    I know this only because this giant hamster named Bopo keeps telling me so.
  • Yashu
    Yashu Posts: 772
    When I had my TT hooked up I noticed that one album would cause my woofers to move to almost max excusion at about 5-10hz... it was quite weird. I never knew if it was the way the album was recorded, pressed, or if it was something else wrong in the way I had things setup.
    This was with my vintage pioneer TT with a new grado cartridge, but it would do this with other cartridges, preamps, ect... but just the one album. I always figured it was just the way it was recorded.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    wow, what speakers were those????
    RT1
    heiney9 Posts: 25,445
    RT1
    Yes, please tell us the speakers and how you measured the output of 5Hz and also what amplifier were you using? Must have been one helluva pair of speakers as well as one very stout amplifier.
  • halo
    halo Posts: 5,616
    Sorry for the de-rail -
    Brock did you get the info I sent you?
    halo wrote: »
    Yes, I did and I tried to send a PM and it says you aren't receiving PM's. So when I get home tonight I'll send you an e-mail.
    Thanks for the info
    Now back to your regularly scheduled program :D
  • bikezappa
    bikezappa Posts: 2,463
    Zombie
    Way back when when I used a turntable, the best way to reduce feedback between the speakers and the turntable was to hang the turntable on the wall with 3 wirers. Yes wires. The wooden floor can move up and down. The walls however don't move up and down. I would mount a screw in the wall and connect it with three wires. The 3 wires were joined together and the turntable would be cradled in between the wires. The 3 wire joint was under the turntable. One wire in the back along the wall and 2 wires on each side of the turntable.
    I could jump up and down next to the turntable with the needle on the non rotating record and see no woffer movement with the turnatble attached to the wall. No turntable sitting on any table ever allowed me to do that.
  • jakelm
    jakelm Posts: 4,081
    heiney9 wrote: »
    About 10-15hz is about the Fr range my 7b's used to wobble with my Linn Sondek TT. If volume was too loud the 7's would pop (those poor , yet fabulous MW6500's). I know the Fr range now thanks to sine wave test disk.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • reeltrouble1
    Interesting, so they would wobble well below the rated Fr response level.
    http://www.polkaudio.com/homeaudio/specs/monitor7/
    RT1
  • jakelm
    jakelm Posts: 4,081
    RT1
    Yes.
    I know many speakers that have fr responses that start to slope in the ~40hz range, but can be over excursed in the upper teens. causing them to "wobble" and pop.
    I'll even try to make a short vid of the action.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
