amp or sub?
ok... been looking at amps for a while now until I got the new receiver in place (HK 340), and am happier than I thought I'd be with it. It vastly improved the sound for my RT5s and sounds very good with the RT16s I just got up and running today. So, having listened to the RT16s for a while now, I am happy with the sound, and am questioning if amplification or a sub will improve the sound of the system more. The 16s sound wonderful with the HK from upper bass through higher frequencies and vocals, imaging and soudstage are more than I had hoped. The low end reach is pretty good on its own, but I do notice it having trouble keeping up with some of the lowest freqs in some classical music... if I had to guess based on the instruements that sound great, I'd say it is very nice down to 40Hz. The difference in sound between a crappy receiver and the HK is substantial... so now I'm wondering if a good amp will produce the same kind of difference (have heard here that the 16s crave power), or if I should go with the a sub to clean up the low end and set the crossover around 60Hz.
So... amp or sub?
So... amp or sub?
______________________________________________
RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable
Post edited by dougr on
I say BOTH are important to have. So start saving more money & flip a coin.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Get a sub.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
Both are important but the sub will be an immediate improvement. No amp will make the bass go lower than the RT16 can go which I beleive is 37hz. A more powerful amp will tighten up the bass and make them less muddy.
Get a sub that will mate well with the RT16. I had a PSW150 (10", 200 watt) I used with the RT16 and it was very good. The Outlaw subs or SVS are probably your best bang for the buck.
V -
You're on a budget, SVS B-stock are some great deals, and good for folks on a budget...
I am not associated with SVS other than owning one of their subs (which I LOVE)Home Theater
2 - Channel
