MYE Sound Brass Pads
hearingimpared
Eight new, never used except as nice things to look at. These are the brass pads that Grant VanderMye sells with his great brass points. I have his points under my 1.2 TLs and they go straight through the carpet into the concreate slab so I have not use in that regard for them. You can do so much more with these because they are solid heavy brass. One thing I would think of doing with them is to place them under existing equipement stock feet and placing a cut out sheet of sorbothanse in place of the felt for more damping control.
These are to protect wood floors or the finish of your rack from the points of isolation cones, brass points or any other type of isolation system that can cause damage. Being the heavy brass that they are they still provide the decoupling or damping that your device is designed to do.
Here is Grant's site pertaining to these. The pad is pictured on the far left.
As you can see the flat side has a nice felt like material.
Sold joeparaski
Sold joeparaski
Post edited by hearingimpared on
bump
again
bump
bump
Joe, will these fit my SRS or 2.3 tl's? If so, I'll take them.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
joeparaski wrote: »Joe, will these fit my SRS or 2.3 tl's? If so, I'll take them.
Joe
Joe I bought them for my 1.2 TLs. The are the pads that the point stands on to protect your floor. They are very heavy and thick for their size so they should work on anything.
If you want them PM me. I still have your addy from the clamp sale unless you have moved since which looking at the picture of all your gear looks like you won't be moving EVER!!! -
If joe does not want them, I'll take them.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
PM sent, yes I want them.
