looking for 6.5" drivers
jimitbone
jimitbone Posts: 17
edited April 2007 in Wanted (WTB) Classifieds
anyone have or know where i might find some middrivers for my sda srs 2 polks "please help" :(
  • Polk65
    Polk65 Posts: 1,405
    edited April 2007
    The SRS 2 used several drivers. Which ones do you need?
  • jimitbone
    jimitbone Posts: 17
    edited April 2007
    i have not taken the speaker out of the cabnet i asume thats where i will find the actual speaker number
  • jimitbone
    jimitbone Posts: 17
    edited April 2007
    the drivers i need are the 6509 which after getting in touch with polk are no longer made they only have a 6511 which will not work any ideas
  • Systems
    Systems Posts: 14,872
    edited April 2007
    They said they will work not work? I'd replace ALL the drivers for a matched set. Then make the needed adjustments to the crossovers if possible? BUT, thats only me. Mom always said..."Chuck you're not stupid.....just crazy"
    Testing
    Testing
    Testing
  • jimitbone
    jimitbone Posts: 17
    edited April 2007
    that's what i think i'll have to do any idea which crossover will be needed and how it will effect the tweeters polk gave me a replacement speaker from another company but thats not the way i want to go
