Polk Audio FXi5 surrounds...Have a couple of questions.
I am thinking about buying these speakers and have a couple of questions.
1. Can you use these speakers in a 6.1 or 7.1 setup.
2. Looking at the diagrams of how the sound travels it looks like the speakers are mounted to the wall. Would I be able to mount these speakers to the cieling without losing the performance in the sound.
Post edited by 1lakerfan on
You can use these speakers in both 6.1 and 7.1 setups. They are meant to be monunted on side or back wall of you room. They are not designed to mounted on cieling. If cieling is the only space you have available then you should look for in-cieling speakers.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Is it ok to use the FXi's in stereo mode aswell? I have RTi6's for surrounds right now but I'm thinking of getting FXi5's instead, I do listen to music in 7 CH stereo alot though...Pioneer ELITE VSX-82TSX
Pioneer ELITE DV-46AV
Carver TFM-35(for sale)
Polk RTi10s(sold)
Polk RTi8s
Polk FXi5s
Polk CSi3
CSS SD12
ED LT550 -
The FXi5 will do very well in 7 ch Stereo mode. By switching them to Bipolar mode, you will get insync music projection from all drivers giving you a nice soundstage.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
here is a question that someone else asked that I also wanted to know but know one replyed.
I just noticed that the FXi3's are rated at being able to handle 150 watts while the larger FXi5's are rated at only 125...is this a possible misprint in the specs? Not that it really makes any difference, I was just wondering if it's a mistake or not...you would think that the larger speaker would have higher power handling, or atleast the same, but not lower...
FXi3: Recommended Amplifier Power 20-150 w/channel
FXi5: Recommended Amplifier Power 20-125 w/channel -
It doesn't matter either way 1LF! My FXI-3's are being driven with 405wpc @ 8ohms & sound great! Both will do just fine no matter what power you give them.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I was just wondering because why are you paying more for the fxi5 and getting less power.
