5.1
kaisersose
kaisersose Posts: 92
edited April 2007 in Car Audio & Electronics
Does anybody have this setup in their car? Does it sound that much better than with the standard 4 speaker and subwoofer combo?
Post edited by kaisersose on
  • kaisersose
    edited April 2007
    What is a good recommendation for a center channel?
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Yes, this is the most common setup. Sub in trunk. It fills the lower sonics that can not be produce well with 6 1/2" drivers. I have done center channel in the past but making a location for it usually is a custom job. Center is not done normally.
    engtaz
    engtaz
  • kaisersose
    edited April 2007
    Yeah the center channel was my main question. I will be doing it on my 1995 Chevy Tahoe 2-door. Do you have to cut the dash?
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    I had honda civic and was able to make a wood piece that would fit in the tray area of the dash. I really don't like cuting up a dash because I don't think it give that much of a benifit in a automobile to have a center channel.
    Just my input,
    engtaz
    engtaz
  • exalted512
    exalted512 Posts: 10,735
    edited April 2007
    I know Pioneer makes a center channel speaker that you can mount to your dash. It doesnt look awful, but I dont think I could do it in my truck...
    -Cody
  • Toxis
    Toxis Posts: 5,116
    edited April 2007
    surround sound in your car. Do you honestly see yourself sitting there watching a 2 hour movie sitting still to enjoy a movie?
  • kaisersose
    edited April 2007
    I think it would be nice for the passengers. Plus you can listen to DVD audio
  • Toxis
    Toxis Posts: 5,116
    edited April 2007
    SACD > DVDaudio and the good news is Sony is coming out with an SACD player for the car. ;)
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2007
    your center should be something like 'half' of a component set... or even a full component set, mounted in the center, wired in parallel.
    cadence makes a 5 channel amp that is specifically for 5.1 sound, with 5 distinct pre-amp inputs.
    good luck finding a deck though.
    The Artist formerly known as PoweredByDodge
  • Jstas
    Jstas Posts: 14,970
    edited April 2007
    You gotta go with one of them in-dash DVD units with the flip out screen. Even then, most of them require a seperate converter box for the 5.1 channel output. Some newer ones don't need a converter box but they are usually very expensive (over $2500 expensive).
    Expert Moron Extraordinaire
