Jensen In Dash DVD Player?
kaisersose
Are there players decent for the money?
What would be a could entry level 4 channel amp for the $150 to $200 range?
Thanks for the help,
David
David
Post edited by kaisersose on
This is the one I am considering
http://www.crutchfield.com/S-nudU37ILhH7/cgi-bin/ProdView.asp?search=jensen&i=110VM9312 -
I would say "no", but only because I have found Jensen to be cheap, poorly made equipment. I've seen far too may threads on the web asking why it sounds like crap when someone's installed one of these.
Ultimately, it's your money, but I'd say going with
http://www.crutchfield.com/S-xzd8yxEgS37/cgi-bin/ProdView.asp?g=168550&I=130AVHP570
http://www.crutchfield.com/S-xzd8yxEgS37/cgi-bin/ProdView.asp?g=168550&I=130AVHP490
would get you 20X better quality for the additional cost.
IMO Jensen and Dual aren't even worth half of what they sell for. Crutchfield has a pretty good return policy as far as I know, so if you aren't satisfied with that Jensen take them up on it ASAP. -
Thanks for the help.
Can you send me one of the threads you are talking about.
Or point me in the right direction. -
At a certain point, you get what you pay for......Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I remember the day- when Jensen was the "in" product- You couldnt touch Alpine or Blaupunkt- Yamaha made amps as well as HK... those were the days
Now... Jensen is sold at finer boutiques accross the country- be weary of these products. -
In all honesty, if youre not looking for great SQ, these decks are actually pretty good.
We've installed quite a few and weve never had one return. Thats more than I can say for some of the Pioneer flip out screens weve had.
Like I said, if youre looking for SQ, theyre not for you. If youre looking for something with video thats pretty cheap, I wouldnt hesitate to go with it.
Makes me feel better since I had it installed over the phone. I am pickup my new truck in Houston on Tuesday.
Do you guys have a suggestion for a good center channel speaker, so I can do 5.1 in the car?
If you can fit it, this Alpine center channel speaker is nice.
http://www.crutchfield.com/S-HfHtS7kdPB6/cgi-bin/prodview.asp?i=500SBS05DC&g=62900&search=Alpine+VENDORID500&SearchDisplay=AlpineAlpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
