Large Low speed fan for garage home theater.
sickicw
I am trying to set up a home theater in my garage-weight room, and was wondering if anyone knows where i could buy a large (36 in or above) box or drum fan, that has a very low speed. I dont want one of thoes really high speed ones because they are loud, and i dont need that much wind.
Edit, i am from fort worth, tx so it can get pretty hot in the summer even with the garage door open.
Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
Post edited by sickicw on
For a 36 + you may want to look at used attic fans. Change the diameter of the pulleys to get the speed you want.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Hello I work in the comfort conditioning industry. Tpi corporation makes a few fans that would suit your needs perfectly. Look them up on the internet.John Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
OK, thanks. ill look into thoes.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
Proud SOPA Member since 2005!
Look into tpi corporation im serious u need a portabreeze probably a 42 inch.John Tyler Birch
home audio system:
Denon avr-1907
RCA TV
NAK 600 tape deck
That was who I was going to suggest -
yea, thoes fan are pretty big. i just think they might be a little too big. Also they would get in the way of the garage door. I think I found a 1/6horsepower fan with 3 speed control from lowes that i might check out. Might have to buy a couple of them. Thanks for all the info...Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
