Polk RT2000P
kaisersose
I just purchased a set of oak. I had wanted black, but I got a decent price in them used.
Is there any advantage to converting them to the 2000i?
Post edited by kaisersose on
Forgot to ask which a better Center Channel match the C400i? or CS1000P? or the CS40i?
Right now I have the RT2000P and the PSW 1000 sub.
Thanks,
David -
David,
Welcome to CP...no clue on your question, though the 1000P is supposed to be the finest center ever made by Polk and I think the match for the 2000P.
Someone with more knowledge should be with you soon.
Are you the mod from AVS?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote:Are you the mod from AVS?
Thats what I was wondering.
I would think the 1000p would be the center to go with. Isn't it powered? -
I thought it would be best match.
I saw one for sale in the classifieds, however I can not send a private message or contact the seller since I am new.
I would apperciate someone giving the seller my information
lesbaer@hotmail.com
Thanks,
David:) -
Forgot to add not familiar with AVS? No I am not the moderator.
A cs1000p is a perfect match. The cs400 is good as well.Fronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
i don't think you can convert your 2000P's into 2000I's. the drivers are different i'm sure.. and those drivers from what I understand are no longer available... at least the original ones aren't.. Polk probably has replacement's for the old "I" series of speakers.. but to me it wouldn't be cost effective.
Oh yeah. congrats on your speakers and welcome to club PolkPolkFest 2012, who's going>?
I have a fairly minty CS400 that I could part with. PM me if you're interested and we can work out the details. I have it posted on Agon (only one on there) currently but can cut you a bit better of a deal.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
there are a few diferences between the 2000p and 2000i, crossovers are slightly diferent as well as the midranges are different too, and also the 2000p has 100 watt amps oposed to the 50 watt amps in the 2000i, other than that the cabinets are the same!:D the birdkaisersose wrote: »I just purchased a set of oak. I had wanted black, but I got a decent price in them used.
