To Mount or Not....
polkatese
polkatese Posts: 6,767
edited January 2011 in The Clubhouse
Polkies,
I need opinion on whether to mount or not, of my LCD 40", on the wall. I was thinking of mount when I bought it, but because of not sure what Sanus' mount package I need to get, I have it sit on a Sony matched XBR34" CRT stand. Surprisingly, it seems to be at about the same height with my old CRT that I get used to it after a while. Anyways, for those who has mounted their LCD higher above eye-level, what is it like? Btw, the reason I am thinking higher is because the LCD is in the bedroom, so from laying down in bed, it seems more ergonomics to have it higher above, ergonomically.
Thoughts? Thanks.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited March 2007
    Check out monoprice.com for mounts. You can get one for $30, and they look rock solid. $30 won't hurt the wallet if you change your mind.
    I'm still debating whether to mount mine or not. I've got plaster walls so I'd have to run my wires in a conduit on the wall. Putting holes in 80 year old plaster is never a good thing, as it likes to crack.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited March 2007
    I can't think of a good reason to not mount a flat panel on the wall. It'll be a bit more work dealing with the wiring issues, but there's a good thread going on in the basic hook-up/wiring forum about just this.
    FWIW, I saw an article that said something like 75% of flat panel purchases were made by women, just for decorating purposes. I know the only reason we have our 50" plasma is because Mrs Rat said, " we ARE getting one, and HANGING it on the wall".
    I think it had something to do with keeping up with the Jonses (Clay's in this case)
    My equipment sig felt inadequate and deleted itself.
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2007
    Do it to it, broham!
    The top of my plasma is a just a skoshe higher than my SRS's and it seems pretty good. No fatigue, at least in the neck and head, during extended watching sessions. The only downside is that the SRS's do cut down on the side viewing angle a bit, but 95% of the time there are only folks watching on the couch, not the loveseat.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited March 2007
    Anyone else expecting a picture of a butterface?
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • polkatese
    edited March 2007
    Thanks, guys! It looks like a worthy small project to take...
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2007
    Phew!! That's a relief!
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Rivrrat
    edited January 2011
    It must be wine time in France.
