FS 2 Epson Powerlite 82c projectors
Fireman32
Fireman32 Posts: 4,845
edited April 2007 in For Sale (FS) Classifieds
I am selling these for my captian on the fire dept. He has 2 brand new in the box Epson Powerlite 82c projectors. He wants 500 each or 900 for both plus shipping. They are 1000 new from epson. If any of my fellow polkies are intrested please PM me. Here are the specs
Projection Type:
Epson High Temperature Poly-Silicon TFT
Native Resolution:
XGA (1024x768)
Lumens: (brightness)
2000
Weight: (lbs.)
5.9
Dimensions: (inches)
9.7" x 12.9" x 3.9"
Zoom & Focus:
Manual Focus, Manual Zoom
Contrast Ratio:
400:1
Aspect Ratio:
4:3 Native (16:9 Supported)
Lamp Life:
Up to 3000 Hours in Eco Mode
Off Set Axis:
3:-1 Up (no lens shift)
HDTV Compatible:
YES (480i, 480p, 720p, 1080i)
Special Features:
Full-Funchtion Remote
4-second startup for easy setup
30 degree vertical keystone correction for added flexibility
Powerful 5W audio
Whisper quiet operation
Effective Scanning Frequency Range
Pixel Clock: 13.5MHz to 162MHz
Horizontal: 15KHz to 92KHz
Vertical: 50Hz to 85Hz
Remote Control Features
Features: Source selection, power, page, up/page down, color mode, volume, e-zoom, a/v mute, freeze, resize, menu, help, auto, mouse functions
Operating Angle: Right/Left +/- 30 degrees, Upper/Lower +/- 15 degrees
Operating Distance: 20 ft (6m)
RGB
Analog RBG I/O
Display Performance: Native: 1024 x 768, Resize: 1280 x 1024, 800 x 600, 640 x 480
Input Terminal: Video: Mini D-sub 15 pin x 2, Audio: Stereo mini jack
Video I/O
Display Performance: NTSC: 560 lines, PAL: 560 lines (Depends on observation of the multi burst pattern) Input signal: NTSC, NTSC4.43, PAL, M-PAL, N-PAL, PAL60, SECAM, HDTV: 480i, 480p, 720p, 1080i, Input terminal Video: Composite Video: RCA (Yellow) x 1; S-Video: Mini DIN x 1; Component Video: Mini D-sub 15pin x 2 (in common with Analog RGB connector); Audio: RCA x 2; Audio signal: 500m Vrms/47Kohm
Post edited by Fireman32 on
