4 ohm Speaker Question
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited March 2007
    Just to add to the fun, upping the voltage is much, MUCH easier (read cheaper) in traditional amplifier designs than getting a power supply that can keep up with the amperage draw.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • sousa
    sousa Posts: 17
    edited March 2007
    Okay, so given all of this, then as the OP asked why make speakers with 4 ohm impedences? If it is cheaper to make an 8 ohm amp capable of powering them then do the speaker and amp manufacturers simply want to screw us out of our money? I am sorry if my persistence or sarcastic humor are bothering anyone, this is just very different than what I have learned up to this point.
  • jdhdiggs
    edited March 2007
    It's a design consideration and how the drivers interact with the X-over. If your schematic makes a great sounding speaker that is nominal 4Ohms and dips into 2 ohms, well, if amps can handle it, keep it there. Adding resistance to the circuit is only going to hurt the sound. It can also change the phase and othe charactoristics.
    Also, your logic was traveling down the right path, you just didn't allow it to arrive. (shh, this is secret) A 2 Ohm speaker will play just fine on a receiver rated for 8 ohms, it will just be working much harder and have less overall power available to it:
    Based on 8 Ohm ratings you can find the max rail voltage and at the 4Ohm rating you can find the max amperage rating and as long as you never exceed either of those limits, the amplifier should have no issue driving the speaker.
  • sickicw
    sickicw Posts: 456
    edited March 2007
    I am still trying to figure out why they use 4 ohm speakers. i have never designed speakers before, but i am just going to assume that the lower the resistance, the more power will be transfered to the driver and less turned into heat, thus making it more dynamic and powerfull sounding. But again this is just a guess.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • jakelm
    jakelm Posts: 4,081
    edited March 2007
    LOL...I just said this.....I guess it needs to be repeated to understand
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • sousa
    sousa Posts: 17
    edited March 2007
    I did not realize changing the resistance of the speaker could impact the SQ. I knew the nominal impedence was determined by the circuitry used in the x-over design, but never knew changing it could have negative effects. I just always assumed 4 ohm speakers were made to get more power out of amps that were able to handle the load. Thanks to everyone, sorry if I pissed anyone off with my obvious ignorance on the topic.
  • jakelm
    jakelm Posts: 4,081
    edited March 2007
    Most caps in crossovers need a certain amount of resistance to work properly (filter and store correctly). Raising or lowering the resistance changed the characteristics of the xover.
    Dont be sorry..we are all here to learn..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • sickicw
    sickicw Posts: 456
    edited March 2007
    Yea, but why are all the driver's and tweeters not designed at a higher impedance?
    While I'm thinking about it, i suppose the shape of the box used will also affect the speakers impedance charateristics (at least when we start talking about the lower frequencies)?
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    I design all my home speakers to run at 4 ohms because I use quality amps. Why design a speaker to run at 8 ohms when you get less power from your amplifier? Speaker manufactures design speakers knowing that most buyers are going to use crappy receivers to run there speakers. I don't care if the receiver manufacture says a receiver is 4 ohm capable. Most 4 ohm capable receivers are just current limiting their output at 4 ohms.
    Ben
  • ben62670
    edited March 2007
    The nominal impedance is determined by the drivers, and not hardly affected by the crossovers at all, unless giant inductors are used to control very low frequency drivers in sub woofer systems.
    Ben
  • jdhdiggs
    edited March 2007
    Want to try this one? Get some cat 5 cable and only attach on pair of wires (there are six wires in the strand, only attach 2) and listen to how it sounds. Now connect some 14 or 16 Ga lamp chord and take a listen. All that difference is due to the resistance difference between the two cables. This will cost you about $4 in parts.
  • JimBRICK
    JimBRICK Posts: 1,543
    edited March 2007
    ok so explain 4 ohm again LOL
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • jakelm
    jakelm Posts: 4,081
    edited March 2007
    More than 5 ..less than 3..lol
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Gaara
    Gaara Posts: 2,415
    edited March 2007
    Hell I always thought the speaker manufacturer tried to make the best sounding speaker possible with a set budget, and if was 4ohm or 8ohm so be it. I have never heard of a company designing their speaker to be 4ohm.
    Jared
    mhardy6647 Posts: 35,237
    edited March 2007
    I'm sorry to be snotty, but: The amount of misinformation in this thread is staggering.
    The standard (well, typical) measurement of speaker sensitivity is SPL (dB) at a distance of 1 meter with an input of 2.83 VAC (typically white or pink noise). 2.83 V is one watt at 8 ohm; it's 2 watts at 4 ohm. The sensitivity of a 4 ohm speaker thus measured will be 3 dB higher than an 8 ohm speaker. That's the main reason many speakers are 4 rather than 8 ohms.
    A power amplifier that can deliver unlimited current will double its continuous power output capability into a 4 ohm load relative to an 8 ohm load. If it cannot, it is indeed current-limited (as has been, correctly, noted).
    A word about impedance. Impedance is NOT resistance. It's like resistance in that it obeys Ohm's law. It is unlike resistance in that it is the vector result of three quantities, resistance, capacitative reactance, and inductive reactance. The latter two (at least) are frequency dependent, so impedance varies with frequency. It is possible to build filter networks ("crossovers") which minimize the variation of impedance with frequency, but ALL speaker systems will display an impedance peak at the system resonant frequency. The nominal impedance of a fullrange speaker system is usually measured at 100 to 200 Hz, or somewhat above the HF skirt of the resonance peak impedance (whichever comes first).
    http://www.polkaudio.com/forums/showpost.php?p=551400&postcount=8
  • Systems
    Systems Posts: 14,872
    edited March 2007
    The crossover most certainly does affect a speaker systems impedance.:)
    Testing
    Testing
    Testing
  • zingo
    zingo Posts: 11,258
    edited March 2007
    I believe another reason that car audio companies make car speakers at 4 ohms and below goes back to the idea of Ohm's Law. 200w at 12v equals 16.6 amps. 200w at 120v equals 1.6 amps. You can draw 16 amps from your car no problem. However, if you have an amplifier that is drawing 16 amps on your house circuit, that could pose a problem. Hope this helps.
  • Jim Shearer
    Jim Shearer Posts: 369
    edited March 2007
    You may not find this relevant, but FWIW, I don't think that the speaker manufacturer's are trying to make your life difficult by building 4 ohm speakers. Speaker design is a very complex task, with many competing factors. If you want some background on speakers and design, there are many sites on the internet which might help you. Here are a couple where you can hear from folks who are professionally involved. (These were previously posted by others on CP.)
    The Soul of Sound page: http://www.nutshellhifi.com/library/index.html
    Articles section of Elliott Sound Products page: http://sound.westhost.com/articles.htm
    As to the problem of driving 4 ohm speakers, look for the thread 'Why 4 Ohm Loads Stress Your Amplifier' on the AudioKarma.org site:
    http://audiokarma.org/forums/forumdisplay.php?f=13
    Cheers, Jim
    A day without music is like a day without food.
    heiney9 Posts: 25,504
    edited March 2007
    Good stuff Jim, I had actually forgotten about the Audiokarma thread.
