HPF for MM2104 subwoofer
I own a MOMO MM2104 subwoofer. On the spec sheet it says 24-200, which I am assuming is +- 10 db (because it doesn't specify) My real question is what HPF is suggested for this model to protect it from the really low frequencies that aren't musical, and to make it more efficient. Thank you for your consideration!
Post edited by Beatmasterphil on
  • Beatmasterphil
    Beatmasterphil Posts: 2
    edited April 2007
    mmmmm.... lots of looks, but no reply... is it that many people don't use a HPF on car subs? I would just put a filter on that would take frequencies at 20hz to -10db but since the frequency response seems curiously low, I was just checking. Any info is very much appreciated! Thanks
