wiring canundrum
vawakemonster
I am running a power wire less than 10 feet form the battery to a distro block. From the Block I will be powering one 60x2 amp (speakers)and one 300x1 Sub amp. so a total of like 420 RMS watts. I can get Deka 6 Gauge wire for free at my work But I do not know if I need to bump it down to 4 Gauge.
So what do you think 4 or 6 gauge for 420 RMS watts
Dodge Dakota
HU: Pioneer
Amp: Profile AP600 & Phoenix gold r2.5:2
Speakers: Boston SX 6.5 components
Subwoofer: polk mm2104
HU: Pioneer
Post edited by vawakemonster on
technically, for that run, you could get away with 10 awg. i would feel for comfortable with 8, but 10 would work.
so... 6 is plenty large enough, and 4 is just plain overkill.The Artist formerly known as PoweredByDodge -
Wow are you sure?
Should I use a fused block or just put a fuse next to the battery on the cable?Dodge Dakota
HU: Pioneer
Subwoofer: polk mm2104 -
fused block and one next to the battery.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Forget the fused block. If your amp already has a fuse in it and youve got one at the battery, adding another will only add resistance to the line.
Just use a normal dist block.polkaudio sound quality competitor since 2005
i agree with macleodThe Artist formerly known as PoweredByDodge
so why not run a fused distro block? That's what I've run for years. To rely on the fuses in an amp is almost to late in most cases. I fuse the power cable (within 12 inches) and then the block to protect each amp. Resistance, sure but honestly how much resistance can it really cause?Never kick a fresh **** on a hot day.
Safety, yes. Bird with a parachute, too much.
What amp fuse do I need fora power wire going to 420 watt RMS distro block?Dodge Dakota
HU: Pioneer
