Ne HT need Speaker Advice!!! Please!!!!
Hi everyone, okay I am building a dedicated ht in my basement, 12 ft wide by 14 ft long, and seating will be 12 ft back from 92" screen, two feet from the back wall, and I am thinking of going with a pair of RTi8s up front, a CSi5 center, and a pair of FXi3 surrounds with a psw404 sub. Would this work in this size room? Will I be getting the best bang for my buck, as my funds are limited. I want to keep it under $2700. I am going with a 92" front projection system with a Infocus 76 projector. The receiver will be a Denon 2807 or 2808. Please if anyone has any advice at all, let me know. Thanks everyone.
Post edited by jedintie6 on
Nice equipment.
Although polk recommends the 404 with that speaker setup, you can get more bang for the buck. Check out SVSound.The Escape Pod Equipment
Samsung HL-S5679W
Sony STR-DA5200ES
Outlaw 7125
Sony 60GB PS3, Blu-ray Disc
TiVo Series 3 HD
Universal Remote Control MX-900
Polk Audio LSi9 ebony, fronts
Polk Audio LSiC, center
Polk Audio LC65i in wall, surrounds
SVS PB12-Plus Piano Black
Outlaw PCA interconnects
BetterCables for HDMI & SUB
Master Bedroom
Sony KDL-46XBR4
Sony 40GB PS3, 2nd Blu-Ray Disc
Polk Audio i-Sonic -
I think your planned setup is at a good price/performance level. Based on how much I am willing to spend I settled in a similar place and am satisfied. I auditioned a lot of speakers and I think the RTi line is very good for the money. The room size is fine for those speakers/receiver. My family room is 13'x23' and I have no problem whatsoever driving a similar setup even with a less powerful Denon and no amp.
I agree with others who have chimed in... Polk subs are currently not on par with the rest of the Polk lineup. I think the SVS is only a little more expensive than the PSW404 (maybe $150 or so?). Good luck.
Mains: Polk RTi8
Center: Polk CSi5
Surround: Polk RTi4
Sub: SVS PB10-ISD
Receiver: Denon AVR-687
TV: 56" JVC HD-56G787
Game Console and MP3 Streaming: Xbox 360
Remote: Harmony 880 -
Hi
I have a similar room 13 x 15. I'm struggling on what to choose. In my opinion I feet that the RTi8 and the CSI 5 might be a bit too much for that size room, considering you are on a budget. Listen to the rti6's. Theyre pretty good and HALF the price of the 8's. Also, if you choose to drop to the 6, consider matching it with the CSI3 which is similar size/characteristics as the 6's and the FX3's.
As for the sub...I agree. Drop the 404 and go with the SVS PB10. I'm ordering that one on advice too. PB12 is too much for that size rm
My 2 cents
Chimera -
Too much is always better than not enough.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Pepi28 wrote:Too much is always better than not enough."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
