Sound insulation for ceiling
reeltrouble1
reeltrouble1 Posts: 9,312
edited March 2007 in DIY, Mods & Tweaks
The ceiling in the New Woodshed is presently drywall nailed to the floor joists above, actually there are the joists then a sub floor above the existing drywall ceiling. I need to keep the sound from traveling up through this and disturbing the Mrs. in our bedroom. What are the thoughts on ways to do this?
Thanks.
RT1
Post edited by reeltrouble1 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2007
    Any technique that would work on a wall, should work as a ceiling also. The sound waves hit the ceiling vibration the floor joists supporting the ceiling and floor. So what I'm thinking (not 100% sure myself) is that you would need to make another ceiling yuk, but this one an inch or so lower then the first one. Removing the first ceiling add insulation to deaden the sound a little couldn't hurt either.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    edited March 2007
    Ok just read insulation is a bad thing.... Kill that idea.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited March 2007
    Read some of this, it should get you into the right direction... HandyMan. ;)
    http://www.soundproofing101.com/soundproofing_4.htm
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    dorokusai Posts: 25,638
    edited March 2007
    You can purchase soundproofing insulation and it would work just fine in between the joists.
  • reeltrouble1
    edited March 2007
    Thanks. I will keep my hard hat on, cant afford anymore brain damage.
    RT1
