marantz vs yamaha
edited March 2007 in Electronics
is marantz considered a BRIGHT reciever?
I have a yamaha now but not happy
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
Welcome!
    edited March 2007
    my Marantz was not bright at all..
    PolkFest 2012, who's going>?
    edited March 2007
    Marantz SR-8500 AV Receiver for 499 US seems like a good deal to me
    2 CHANNEL
    Under construction
    edited March 2007
    G'day JimBRICK,
    I have both and I find the Yammie brighter. Musically, Marantz usually kills it and Yammie does it for HT (in my opinion).
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
    edited March 2007
    I find all this receiver and amp talk in sound qualities to be somewhat humorous for the most part, no offense given.
    Some receivers and or amps actually attenuate and frequency range to give their product a little different flavor, but thats all in the mid to high end region of pricing.
    Everything else boils down to the power they consume and output.
    Brick and Mortar named products, claiming to put out over 50 wattsper channel can only do so on upper end frequency's, not lower, sub 100 hz. Their power supplies and or amps just dont have what I call the torque to drive sub 100 hz at the 50+ wattsper channel. So lower frequency's are down in DB versus higher ones, making them go what people call bright. All attenuation is placed at higher frequency's because the amps and power supplies cannot put out enough to drive lower ones. 100 hz is not even close at some times, just a example is all, some maybe even much higher before they run into trouble producing equal DB throughout the frequency range.
    Better receivers and the list is much smaller, Marantz, HK, Denon, Onkyo dont share this problem driving low frequency's and you'll find there actually pushing closer to there ratings across the frequency range. They wont attenuate brighter sounds due to lower frequency's DB's are up.
    I call this Torque.
    Vehicle engines can have all the horsepower in the world, but if they lack torque, there slow to move and cant sustain speed very well at a fixed pedal amount. A vehicle with much less horsepower, but with a greater amount of torque can accelerate faster and sustain speed with less pedal control.
    Think of it this way.
    Ever see Fast and Furious????
    What wound you rather have to push or pull a load???
    The Rice burner whom can barely smoke the tires at launch or the Mopar at the end of the movie that wheel stands?????????? Same applies to receivers!!
    edited March 2007
    I get yah. well I win the marantz in 10 minutes so I will see when it gets here
    2 CHANNEL
    Under construction
    edited March 2007
    While John has done an admirable job trying to explain 'brightness' it doesn't explain why some people complain of shrill on amps such as Bryston and Krell. Use your ears...they usually tell you what's going on much better then what white papers can. I do think Denon and Yamaha lead the pack in terms of overall value. The latest Denon 38 series and Yamaha RX-v2700 can't be touched in their respective class in terms of value.
Welcome!
Welcome!
