Help setting up Denon 3910 please
joeparaski
joeparaski Posts: 1,865
edited March 2007 in Electronics
Ok, let me try to get help again on this topic. First of all, yes, I AM reading the manual to the 3910, albeit sporadically due to my busy schedule.
Yes, I suppose I could go to the AVS forum, but I prefer THIS forum.
Yes, I could experiment, and I did, but I"m getting nowhere and getting blue in the face, and I don't have much time on my hands. I'd rather be listening than spending an ungodly amount of time trying to make it work.
So....I replaced my Panansonic S77 with the Denon 3910. The S77 was working fine. The pre-pro is an Emotiva LMC 1. Everything seems to be hooked up correctly, I"ve got the toslink for audio and component for video.
The picture is fine, but I get no dialogue from the movie. Can someone please tell me what the typical settings are in the menu for the Denon 3910? I'll be monitoring your responses and I'll have a go at it again on Saturday night. Next week I have some guests and I'd like to at least watch a movie with ALL the sound and dialogue.....I suppose I could activate the subtitles, but that would generally suck.
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • Mike682
    Mike682 Posts: 2,074
    edited March 2007
    When I got my new DVD player I did not get any sound. I had to enable digital audio out in the DVD's menu system when I used the optical out.
    You probably already did it, but do you have the audio digital out enabled in the Denon's menu??
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Are you using the same A/V inputs into your system? If so, try going thru the onscreen setup to select audio output. If you are not using the same inputs into you system then you need to change your system setup to select your change in your audio input.
    Good Luck,
    engtaz
    engtaz
    tonyb Posts: 33,067
    edited March 2007
    You have a nice piece there joe in the 3910. But it's not a plug and play machine.Take the time and read the manual,your problem is in the setup menu as there are numerous choices.
  • Sansui
    Sansui Posts: 372
    edited March 2007
    I hope I don't have his problem! In about an hour I'm buying a Denon AVR887 to replace my Onkyo with and I've heard that the manual isn't "that friendly".
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Denon AVR's just set audio input to auto if you can't get it working or do the step method by watching the video then stepping thru the audio input. Just remember the video inputs are not chargeable but audio is.
    engtaz
    engtaz
  • Sansui
    Sansui Posts: 372
    edited March 2007
    engtaz
    Thanks for the advise! I heard the auto setup sometimes isn't all it's supposed to be. If I try to set it up without using "auto", should I reset the processor first and then do the auto setup if I have to use that feature?
    You mean video inputs are not *changeable*, correct?
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    1. Easiest is the on screen setup. My unit would only work on s-video. Just write down which video goes with each audio. The red white (analog) audio is directly related to the video. Digital audio is selectable.
    2. Yes,spell check doesn't catch everything. Ha Ha
    engtaz
    engtaz
  • Sansui
    Sansui Posts: 372
    edited March 2007
    engtaz wrote:
    Spell check doesn't catch everything. Ha Ha
    engtaz
    Understood... Leaving for C.City now to get it.
