Upgrading the Unit from RT1000P to RT 1000i
Nisqually Dave
Nisqually Dave Posts: 220
edited March 2007 in Vintage Speakers
Is it possible to upgrade a RT 1000P to a 1000i, when I set them up on home theater I can tell the difference in sound Between the RT1000i and the the center 400i and the rt 1000p.
Also what would produce the best sound for my rear speakers surrounds the LS/fx's or use my old LS 50's for the rears.
one final thought I have a chance to pick up anouther set of RT 1000 i's would they work well for the rear surounds also? and is the price of 275.00 a good price on these good. I will have to take a round trip of about 300 miles to get them though.
Dave
Post edited by Nisqually Dave on
  • Skynut
    Skynut Posts: 2,967
    edited March 2007
    275 is a good price if they are clean.
    I would travel 300 miles for them if I needed/wanted them.
    As for rears I think they would be a good rear speaker if you have the room.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Nisqually Dave
    edited March 2007
    Thanks for the info, I have the Ls 50's and question if they would work well for rear surrounds if I get these rt1000i I will have three Rt 1000i's and one rt1000p
    Nisqually Dave
