Quality Component vs Mediocre HDMI
PSOVLSK
PSOVLSK Posts: 5,235
edited March 2007 in Electronics
I recently got a Denon DVD557 and I have it hooked up with the ViperAV component cable that my old player was hooked up with, as well as a new HDMI cable. The DVD player only upconverts via HDMI, thus the reason for buying the new cable. When I do switch from Component to HDMI, I can't tell a difference. I'm guessing the reason I can't tell a differnce is one of the following:
1) There really isn't much difference between component and HDMI.
2) I'm using a quality component cable, but my HDMI cable is mediocre. (I know this is true of my cables, just didn't know if that's the reason for my lack of impovement in PQ).
3) I'm blind as a bat and need to quit wasting my money on decent cables.
Here's my room specs, etc:
Dedicated HT room, dark walls, completely dark inside
Panasonic AE900U projector
I've never measured it, but my screen is about 110"
Viewing distance of 12'-13'
Post edited by PSOVLSK on
  • Sami
    Sami Posts: 4,634
    edited March 2007
    The answer is #1.
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2007
    The only difference I noticed when switching from component cables to HDMI:
    1. Picture was centered a little better (DVE)
    2. The halo you see in certain scenes around Marlin in "Finding Nemo" finally disappeared.
  • VSchneider
    VSchneider Posts: 443
    edited March 2007
    #1 +1
    I did a similar test with my DVD557, and there's a slight difference, but not a " :eek: what was I watching before :eek:" difference. Diagonals on the screen are straighter and less jagged, fine detail like hair looks better, the image is slightly sharper overall. The main benefit by far is hookup convenience for me.
    - Val
  • AndyGwis
    AndyGwis Posts: 3,655
    edited March 2007
    I just picked up a Sony DVP-S9000ES for my bedroom setup. My previous player was an upconvert hooked up HDMI - DVI. This one only does component.
    Is it worth dropping some cash on new component cables instead of the gimme's I had laying around? What are some good options on the cheap? Only need 1M / 3ft.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • shack
    shack Posts: 11,154
    edited March 2007
    Problem solved....cheap!
    http://www.polkaudio.com/forums/showthread.php?t=50752
  • AndyGwis
    edited March 2007
    I'm on it. That just might be the ticket. . . if my bro can't come up with some in his bag of tricks.
  • shack
    shack Posts: 11,154
    edited March 2007
    That's a quality set of component cables for what you would pay at Wal-Mart for generic stuff. Street price is usually around $50.
  • Monster Jam
    Monster Jam Posts: 919
    edited March 2007
    I don't know about the rest of the post, but the "quality" of an HDMI cable should never be part of an equation. It works - or it doesn't work.
    Do you hear that buzzing noise? :confused:
  • AndyGwis
    edited March 2007
    Maybe someone can expand on Monster Jam's claim. I know HDMI is digital and loseless (I think that's the right word). So, that means signal degradation, interference, etc. doesn't come into play at all, right?
    How does Monster (cable, not jam) get away with $120 hdmi cables? I just got a $20 BJ cable HDMI, cheap and looks good.
  • steveinaz
    edited March 2007
    You can have both quality/low price. Blue Jeans cable made my HMDI (24awg) cable, $24.99.
  • Sami
    Sami Posts: 4,634
    edited March 2007
    There is error correction in HDMI standard, not sure how (well) it works though. A cheap cable will work just as well as an expensive cable, especially if you're not running it long lengths.
  • PSOVLSK
    edited March 2007
    I guess my #2 statement should read: My component cable is relatively expensive and my HDMI cable is relatively inexpensive. I was making the assumption that higher price=higher quality. I had never heard what Monster Jam said about HDMI. I could have saved $15 and gone with an even less expensive cable than I got.
    FYI: I've bought a few cables from overstock.com at pretty good prices. BaggedLancer posted a thread a few months back about an otical cable there so I checked it out. Decent selection on a variety of cables...with low shipping cost.
    And by the way, it's nice to see that no one suggested option #3 was the problem:D
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2007
    My feeling is cheap HDMI cables can cause problems like impedance, capacitance in the cable. Thus causes errors in the overall picture. Maybe on a short length cable these errors don't add up to much so no-one really picks up on it?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2007
    i like it beacues it dues audio and vid it is easy to conect and you have less cables
    the downfall no pres do hmdi 1.3 with the new hd audio and olny a few have more than 3 switching and with 2 dvd players a ps3, comp and cabble there is 5 and if i get the new xbox 360 with hdmi i am sol with my 5x1 switcher
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2007
    I agree, a cheap HDMI cable will show no different than a longer one. I tested this out with my HD DVD player, I bought a nice thick audio technica HDMI cable off the Japanese market, total price was 12,000 yen (108.00 US). When my HD DVDp showed I tried both cables and had the same reult. Now my Blu Ray player on the other hand, thats a total different animal, simply due to the fact that they dont come with a HDMI cable. Save yourself the buck and get a cheaper quality cable unless you want something that looks good.
  • Holydoc
    Holydoc Posts: 1,048
    edited March 2007
    Psolv,
    When you hooked the HDMI cable up to your source did you then set your source up so that it would upconvert? Did you upconvert to 720p or 1080i? When you upconverted did you get the same resolution as when you used component hookup?
    If you are feeding the same resolution to the projector via component and HDMI, you are going to get nearly the same picture since your projector will be doing all the upconversion for you instead of your source.
    Once you experiment and you still see no difference, then you can say that it does not matter on your particular source which connection you use. Now you just need to decide which connection is most convenient for you to use.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    i vote for answer #1 too.. there really isnt' much difference between comp and HDMI.. picture quality wise.. lots of people think there is because HDMI is digital while component is analog.
    PolkFest 2012, who's going>?
  • PSOVLSK
    edited March 2007
    Holydoc,
    I have my DVD player set to upconvert to 720p, which should be a higher resolution than my component hookup. I think I have everything set up correctly, but since were talking about me, there could be something set up wrong.
    As for convenience, I'm making things inconvenient for myself for no good reason. I'm running my video straight from my source to the projector, bypassing the AVR. If I were a smart man, I'd run component from DirectTV and DVD to my AVR and then component on to the projector from the AVR. This would save a couple of button pushes on the remote and I'm sure the PQ would be the same.
  • shack
    shack Posts: 11,154
    edited March 2007
    PSOVLSK wrote:
    As for convenience, I'm making things inconvenient for myself for no good reason. I'm running my video straight from my source to the projector, bypassing the AVR. If I were a smart man, I'd run component from DirectTV and DVD to my AVR and then component on to the projector from the AVR. This would save a couple of button pushes on the remote and I'm the PQ would be the same.
    I run straight from my DVD player to my RPTV. My thought is anytime I can avoid another switch of the signal, the better.
  • adam2434
    adam2434 Posts: 995
    edited March 2007
    With my upconverting DVD player, HDMI at 720p or 1080i looks better than component because of the upconverting/resolution - not because of the cable type.
    I believe this to be true because when I switch back and forth between HDMI and component with high def cable TV (same resolution for both), I can't see a difference.
    BTW, both cables are from Blue Jeans - good quality for the money.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • disneyjoe7
    edited March 2007
    Then I think the difference is also not by cable type being Component or HDMI but the TV. As some one stated here (Sorry don't remember who) maybe the component circuit is skipped on where the HDMI is not.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
