How does this rate?
TennesseeOutlaw
TennesseeOutlaw Posts: 414
edited March 2007 in Electronics
Continous Power- 120 watts 20Hz-20Khz .003 THD 8 Ohms
Dynamic Headroom 8 Ohms- 1.25 Db
Damping Factor @ 1Khz 8Ohm - 130
Input Sensitivity/Impedance (Main in) 1.07v/20k Ohm
Channel Seperation 40Hz- 106
1 Khz- 89
10 Khz- 70
Total Harmonic Distortion- Main In- to SP Out 60W/8 Ohms - .002%
Residual Noise {IHF-A-Network} 16uV
Signal to Noise Ratio- Main in Shorted/5.1 K Ohms - 127 Db/ 119 Db
Post edited by TennesseeOutlaw on
  • WilliamM2
    WilliamM2 Posts: 4,782
    edited March 2007
    The specs look decent, except the headroom is lacking.
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2007
    That's not uncommon for 75% of amplifiers on the market.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    You don't need a whole lot damping at 1Khz. I'd rather see it spec'd at 100Hz or lower. THD is super low, probably a TON of negative feedback in the circuit to get it down that low, which is not a good thing.
  • TennesseeOutlaw
    edited March 2007
    Well, this is an old vintage 1985 Yamaha M-40 I picked up today for $100.00 bucks (plus $35.00 shipping).. Figured I really couldnt go wrong. Just wanted to know what a few people thought about it. Thanks for the replies.
    Josh
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2007
    Exactly. Just numbers, what's the brand?
    Better give that Yammie ALOT of breathing room, they run HOT.
  • TennesseeOutlaw
    edited March 2007
    Anyone know or heard anything about this particular unit?
