Antique Sound Line One Preamp
SolidSqual
Has anyone had any experience with this preamp? Its specs aren't too shabby and it fulfills my quest for a reasonably priced preamp with two line outs and no unecessary frills. Unfortunately, I can't find anyone around here who has one to test.
http://www.divertech.com/asllineone.html
TECHNICAL SPECIFICATIONS
Frequency response at 1.0 Volt: 20Hz- 20.000 Hz. +/- 1dB.
Frequency Response at full power: 10 Hz- 18.00 Hz. +/- 1dB.
Distortion at 1Volt: <0.5%
Distortion at full power: <1%
S/N Ratio: 79dB
Input impedance: 100k Ohm.
Output impedance: 1.0 kOhm.
Input sensitivity: 150.mV.
Output: 2.0 Volt.
Power consumption: 21 Watts.
Tubes used: 1 / 12AU7
Fuse: 1.0 ampere slow-blow.
Dimentions: 8" wide, 9.5" deep, 2" high.
Weight: 3.5 lbs.
S/N Ratio: 79dB
Output: 2.0 Volt.
Weight: 3.5 lbs.
