Great tweak for HK owners
Ern Dog
Ern Dog Posts: 2,237
edited March 2007 in Electronics
I'm so stoked on this cheap tweak, I just have to share it for those who aren't doing this already....
I've always had my universal Onkie dvd/cd player hooked to my HK via toslink then played cd's using stereo mode. Today I hooked it up the Onkie via quality RCA cables (signal cables), in stereo mode, but switched the DSP mode off. WOW, what a huge difference turning the DSP off does. The HK won't allow you to turn DSP off using a digital input, only analog. It has totally opened up the whole system. I never realized how congested and muffled my system sounded until now! Try it.
Post edited by Ern Dog on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2007
    Nice find..........next step is a tube preamp. No contest for me between my HK and my tube preamps. I still use the HK for movies, but for 2 ch. SACD/CD/Phono sessions, no contest.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2007
    I guess I'm not sure what you are saying here Dog. What DSP mode are you talking about?
    I think what you are comparing is simply the difference between the H/K DAC and the DAC in your Onkyo.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
    tonyb Posts: 33,020
    edited March 2007
    BINGO !!
  • Lowell_M
    edited March 2007
    The DAC in my CDP sucks. I much prefer the h/k.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • AndyGwis
    AndyGwis Posts: 3,655
    edited March 2007
    Would the DACs in my Toshiba HD-XA1 be better? I've always used digital coax connection for music and movies because it had better bass management.
    I guess I can go with the 5.1 analog outs and go with direct (6/8 channel analog in) on the HK.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2007
    There's a huge difference between analog and digital connection for me as well. I listen to all 2 channel via the 6/8ch input rather than Stereo, which sounds like the soundstage is cut in half.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Ern Dog
    edited March 2007
    No that's not it. Because what I'm experiencing is happening even when I'm just listening to the tuner w/no DACs involved.
    Let me explain more. When listening to the tuner in stereo mode, keep pressing the "stereo" button on the remote and it gives you 3 options: 5 channel stereo, stereo+DSP or stereo (pure). I didn't know I had this last option until just recently. So then I tried to listen in pure mode to my CDP, but couldn't do it using an optical cable. With an optical input it only gave me 2 options: 5 ch stereo or stereo+DSP. I added RCA cables and changed the input to analog and problem solved. You'll know when the DSP is on because there is a "DSP" indicator lit up on the display. It is literally a night and day difference with it on and off.
    I agree that the DACs are different between the cdp and HK, but this difference is barely noticeable in my system to my ears.
  • Ern Dog
    edited March 2007
    I tried the 6/8 input too and found I lost my sub. I'd need to add a splitter to add my sub into the 6/8 inputs.
  • Ron Temple
    edited March 2007
    Yep...you lose the sub unless it's MCH. I don't mind with the SDAs as sometimes the sub's too much.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • rt7s
    rt7s Posts: 29
    edited March 2007
