Blade/blade connector dimensions
strider
I know this may be a long shot, but does anybody have the dimensions of the small and large blades on the ends of their SDA interconnect? I know the thickness may be hard to measure without a micrometer, a guesstimate of if it's slightly bigger/smaller then 1/16th of an inch is fine. I made my own cable and want to make certain the ends on it are as close to the original dimensions as they can be. Thanks!
Wristwatch--->Crisco
Post edited by strider on
.220width x .410length x .045thick wide blade
.155width x .410length x .045thick narrow bladepolkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Ya beat me to it because I had my micrometer and dial calipers but had to find my reading glasses:D
I keep mine on my nose:)polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Give me a few minutes and I'll tell you where to buy a connector_________________________________________________
Here you go; in post #15 you'll find a link; I built a blade-blade using these and worked perfect.
http://www.polkaudio.com/forums/showthread.php?t=32855&highlight=blade%2A_________________________________________________
You guys rock! That link's perfect, HT, I have an account with Allied already. Thanks again.Wristwatch--->Crisco
Ben -
ben62670 wrote:
Ric & Ben the blade/blade is easy, I've been searching high and low for a pin/blade that I don't have to jerry rig. -
hearingimpared wrote:Ric & Ben the blade/blade is easy, I've been searching high and low for a pin/blade that I don't have to jerry rig.
IMO, from seeing your handywork with the clamp, and hearing how you've helped set up people's turntables (which just about drove me insane because they gave me the wrong directions :eek: ) I think you'd be fine to put in another set of binding posts and run some good ole speaker cable between 'em!
Just thinking about it some more, couldn't you put a banana plug on the end of a length of speaker cable and use that as your pin? Never seen a pin/blade in person, just trying to brain storm.Wristwatch--->Crisco -
Raife has some nice plans on IC cables if you're planning on getting away from the stock version.
I just gave what you asked for..."the dimensions".polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
read-alot wrote:Raife has some nice plans on IC cables if you're planning on getting away from the stock version.
Yes, you certainly did, thank you very much. I 've never seen any SDA IC in person, I aasumed that I needed to "make something work" in regards to the connectors. I had no idea you could buy something off the shelf that would work, too. You were definitely one of the "guys" in the "you guys rock" comment.
I just got the Compendium last Friday, which has been the impetus for me diving back into my SDA's with 2 feet. I've been debating with myself over the past few months about my soundstage, wether I was getting the SDA effect full force or not. So, I'm re-analyzing the work that I've done with them, making as certain as possible that what I've done hasn't been subpar. Jury's still out.Wristwatch--->Crisco -
I was just reading about the IC upgrade in the Compendium last night and it helped the depth field but left the width according to the doctor.
When I find time it is on list to do right behind the caps and resistors.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
strider wrote:IMO, from seeing your handywork with the clamp, and hearing how you've helped set up people's turntables (which just about drove me insane because they gave me the wrong directions :eek: ) I think you'd be fine to put in another set of binding posts and run some good ole speaker cable between 'em!
Thanks for the compliments and the tip.:) The biggest problems I face these days are the 50+ year old eyes and the 50+ year old shaky hands. LOL
