I need a little help with picking a cheap projector
ben62670
I am looking for a projector for computer/HT use. The room that it will be in use is 20x20. I have fluorescents in the back, and know I need to run it with the lights off in the front. I was looking at 1024 x 768, and 800x600. The BenQ's come with an extra bulb quite often. Will the resolutions of such projectors work fine with component signal from a DVD player?
Thanks Ben
Thanks Ben
Ben
Ben
Post edited by ben62670 on
Mitsubishi HD1000U 720P VGA,Svideo,Component,Composite,HDMI inputs. www.projectorpeople.com No Aff.
what ranges of spending are you looking into?
engtazengtaz
you might want to look into getting a projector that supports the resolution of a 720p movie or upscaling 1366x768. just a thought. is a projector necessary because plenty of tvs our there are cheap now?
also try epson, they have a model 400 that is ok
I like my Optoma H30 and would step up to the Optoma H72 for HD material when I'm ready. Any of the current PJ offerings will do nicely with component and many use HDMI.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I have this projector and it is a great one with a very good picture and good features and the lamps last for 3,000 hours and cost $150 new...
http://cgi.ebay.com/Epson-Powerlite-Home-10-LCD-Projector-1200-Lumens-HDTV_W0QQitemZ150101804420QQcategoryZ75416QQrdZ1QQcmdZViewItem
here is the review:
http://www.projectorcentral.com/Epson-PowerLite_Home_10+.htmMy gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
IMO, CRT projectors provide the best $/performance ratio due to the fact that the tubes last 10,000 hours. A friend of mine who has an LCD projector has already gone through 2-3 lamps, so CRT PJs are a bit more reliable (IMO).
Check out www.audiovideotechnician.com and www.crtprojectors.co.ukpolkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
