Running 2 center channels????
bassaholic
bassaholic Posts: 315
edited March 2007 in Speakers
What is the proper way to hook up 2 center speakers? Can I just run a jumper off 1 speaker and into the other? TIA, Steve
Pioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
Post edited by bassaholic on
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2007
    If you just 'jumper them', you are either going to double the resistance or halve the resistance depending on your method. The Monster might throw a fit if you halve the resistance, or maybe not.
  • Face
    Face Posts: 14,340
    edited March 2007
    What would be the advantage to this?
  • bassaholic
    edited March 2007
    I don't know. If there is one, I will post it when I find out how to do it correctly.
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    I am using 2 monitor 5's off of 2 channel of my GFA-7500 using a y connector coming out of the pre amp. I also have done it using one channel, and running both wires to the amp= 4 ohms. You can't run them in series because it WILL not work properly with the crossovers, and most likely present a 16ohm load. Check your amp manual and see if it is compatible with 4 ohms. Then check the speakers, and make sure they are 8ohms. It definitely helps with my system to run both, and you get an extra tweeter for the highs.
    Ben
    Ben
  • 98thumpin
    98thumpin Posts: 649
    edited March 2007
    interesting theory running to center channel speakers never hear of this.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • louthewiz
    louthewiz Posts: 581
    edited March 2007
    Why would you want to run 2 center channels which will only throw off the soundstage and imaging in the front array?
    Unless you have a screen that is over 8 feet wide then it would make sense...
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • Systems
    Systems Posts: 14,873
    edited March 2007
    Yes having 2 will mean there will be some comb filtering effects happening.The severity will depend on the actual placement of the 2 in relation to each other.
    Are they the same model?
    On the other hand adding another will increase the output potential. So if you are using a small center and it tended to sound a bit stressed when you played action movies at high levels, then adding a second identical unit would help.
    Testing
    Testing
    Testing
  • Early B.
    Early B. Posts: 7,900
    edited March 2007
    Better sound quality, improved dynamics. Works great. I recommend it.
    Not sure how you concluded that running two center channels would throw off the soundstage and imaging. On the contrary...
    "God grooves with tubes."
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    engtaz
  • whitetruk
    whitetruk Posts: 311
    edited March 2007
    i use two one on top,and one below the screen.driven by a two channel amp,love it
    I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
