PSW12 on a onkyo txsr674, got a "shut off"
n0m3b
Connected to the "lfe" with monster cable and annoying the neighbors
So did I put the amp output into self protect or the sub?
Should it be a concern? It is a simple theatre system that rarely does 95db . . .
Post edited by n0m3b on
I think you turned the Onkyo up too loud. It shuts off automatically to protect itself.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Actually should have clarified that only the sub "shut off" and the other speakers continued to play. When the ground quit shaking I checked the sub, turned everything down, reset the system and then the sub started working again.
appadv wrote:I think you turned the Onkyo up too loud. It shuts off automatically to protect itself.
Ah hah, too much input signal. Got it now . . . thanks
Yes, the sub protects itself from too much signal which overdrives the PSW12 amplifier.
That Onkyo is a very good receiver. I have the TX-SR702 (one step up) but previously had a TX-SR500 and it was also a good receiver.polkaudio RT35 Bookshelves
