Onkyo tx-SR703 opinions vs...
dougr
just picked up the onkyo tx-sr703 display model at fry's for $195... cheapest model I could find with up-to-date surround processing and pre-outs. planning on picking up a used adcom 2535 to drive the front soundstage, and drive the surrounds in a 5.1 setup straight from the AVR. my other option at the same price point would be the HK340 with no external amp. I picked up the onkyo because they just dropped the price today, and I didn;t think it would last long (still have a few of the HK340s). did I make the right choice (onkyo + amp), or should I run back, return the onkyo and go with the HK (would be a while before I could get an amp for the HK, so assume no amp).
Thanks,
-Doug
Thanks,
-Doug
______________________________________________
RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable
Post edited by dougr on
I think you're headed in the right direction. The Onkyo should make an OK pre/pro.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I second that.. There is no sense in getting the H/K if your are planning to use external amplification.. If you were just planning to jsut use the AVR as the only power source I would tell you to RUN back and get the H/K.. H/K (IMHO) is a much better AVR and has a warmer sound, but if you are using the Oink just as a pre, it probably has "basically" the same exact thing as the H/K.
Josh -
Great choice! That's an $800 receiver you got for $195!polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
