Question on SRS 1.2TL's
Joelsbass
Joelsbass Posts: 637
edited March 2007 in Speakers
Hey guys,
One of my biggest goals right now (hope that doesn't sound too pathetic) is to have a set of these gorgeous speakers by the end of the year. My problem is that being a car audio guy I'm at a loss on home amplifiers or how much headroom is needed in home audio. That said I could really use some advice on amplifiers to power these beauties and get their full potential but hopefully without spending a small fortune. As far as price goes I'm probably going to put around $1500 into the speakers and wind up driving a good 10 to 20 hours each way to get the speakers (no way in hell would I trust them to freight...) So i'm not going to skimp on the amplifier. SO..... Dedicated 2 channel amplifier or 2 monoblock amplifiers, clean power, good frequency response, durable, and in the $1000-1500 price range...
MacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy!
Post edited by Joelsbass on
    VR3 Posts: 29,550
    edited March 2007
    Odyssey Audio Stratos Extreme.
    180,000 uF of capat
    Two monsterous transformers
    An absolute monster.
    20 year warranty...
    yada yada yada
    http://www.odysseyaudiosg.com/Stratos.htm
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Adcom GFA-555 200@8ohms 325@4 All day long on ebay for $350-450
    GFA-585, GFA-5800 250@8, 400@4 $500-650
    http://www.adcom.com/manuals.aspx
    did you see the SDA1.2TL's on ebay?
    Ben
    F1nut Posts: 52,002
    edited March 2007
    There are any number of excellent choices other than the usual suspects found here. Sites like Audiogon always have a nice selection.
    heiney9 Posts: 25,504
    edited March 2007
    Just like everything else take some time and do some research. There are so many good threads here as well as other sites. One key thing to remember about some SDA's is that you have to use common ground amplifiers and as rule most mono blocks are NOT common ground. Stick with something high current and DO NOT forget how important a good pre-amp and source are to the overall sound. Synergy is what you should be looking for and sometimes experimenting with different gear is the only way to reach nirvana.
    The usual suspects that F1 mentioned can be a great starting point, but still do the reasearch. Also it's important to know what your end goal is going to be. HT, 2 ch, room size, listening habits, music type, etc.
